Port negotiating problem
kpmgnz
Our router (2800) 'int g0/0' is hard set to 'FULL duplex' and 'Speed 100', this is connected to our backbone switch (4503), our issue is when we set the port on the 4503 to 'Duplex Auto' and 'Speed Auto' it sets itself at 'HALF duplex' and 'Speed 100'. We have replaced the cable and tried hard setting the port to 'FULL duplex', this failed and the WAN link went down. Any ideas at what could be the problem? Cheers
rajivrajan1
Level 3
Level 3
both sides auto negotiation won't work
See below documentation and try to keep setting as per specifications.But Even after those settings it's not working let me know the IOS version of both side devices.
http://www.cisco.com/warp/public/473/46.html
can you try to set speed/duplex to auto/auto on both ends and see if it works?
after that clear counters on both interfaces and check for any errors, CRC on both interfaces.
hope it helps ... rate if it does ...
jackyoung
Level 6
Level 6
In normal case, auto/auto should work. Could you advise the LAN module no. of 4503 ? Moreover, do you mean if the LAN of 2800 down, the WAN also down ? Could you provide the config of 2800 ? It is abnormal.
Hope this helps.
kpmgnz
Thanks guys, we had to hardset our and the telco link to 1G FULL duplex. This seems to work fine and we no longer have any issues.
