Community Helping Community
279
Ports 443 and 80
Hello Folks,
I am in need of some help. I have a RDP server on my network that I have set up for external access from the internet. I have also configured my router to forward in the nessecary locations and opened up the right ports or so I thought. I have enabled CBAC on my router to inspect all interfaces inbound and outbound traffic and applied an access list allowing traffic in on ports 443 and 80 to my outbound interface pointing inbound. Yet I am still unable to navigate to the website or IP address externally. I went to "sheilds up!" at grc.com to test my opened ports and they are still saying those two ports are closed. Am I missing something on my access list that wouldn't allow port 443 or 80 based traffic to converse that interface.
here is my configuration:
service password-encryption
hostname ROLIAJ01
boot-start-marker
boot-end-marker
enable secret 4 avq1sKoPiePO9fyYwxoCGtXKX9/uitvC9ih8omI4b1.
no aaa new-model
clock timezone utc 2 0
no ipv6 cef
ip source-route
ip cef
ip inspect name GMRA tcp router-traffic
ip inspect name GMRA udp router-traffic
ip inspect name GMRA icmp router-traffic
license udi pid CISCO1941/K9 sn FGL161920AW
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description External Interface
ip address 81.x.x.x 255.255.255.252
ip access-group 101 in
ip nat outside
ip inspect GMRA in
ip inspect GMRA out
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Interface
no ip address
ip nat inside
ip inspect GMRA in
ip inspect GMRA out
duplex auto
speed auto
interface GigabitEthernet0/1.20
description Vlan20 Trunk
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.10.10.1 255.255.255.128
interface GigabitEthernet0/1.99
description Vlan99 Trunk
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool GMRA 81.x.x.x 81.x.x.x prefix-length 30
ip nat source static tcp 192.168.20.37 80 81.x.x.x 80 extendable
ip nat source static tcp 192.168.20.37 443 81.x.x.x 443 extendable
ip nat source static udp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip nat inside source list 7 pool GMRA overload
ip nat inside source static tcp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip route 0.0.0.0 0.0.0.0 81.x.x.x
access-list 7 permit 192.168.20.0 0.0.0.255
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 3389
Thanks in advanced,
Eddie
Everyone's tags (8)
Content for Community-Ad
FusionCharts will render here
