Power Sensor Senor
james.king14
Good Morning ALL
I have a ASR 1004 RP1 that is giving me this error message.  "Hardware component is in warning and/or critical state" when I investigate it is showing "subslot 0/0 transceiver 0 TX/RX Power Sensor" when I do sh platform cpu it show really nothing.  Is this a fault with the XE IOS or should I be really worried.  I have an attachment to this issue.
6 Replies 6
Hi, the issue seems related to power supply voltage of a transceiver.
Try to post the result of command  'show int transceiver details'.
In this way we can check for power voltage issue.
Regards.
HI,
That command is not able to run on my IOS. Any suggestions?
Can you try with "show controller"?
Regards.
The information is in the attachment.
Can you post the actual error message?
PremNaresh2556
Verify that Gi0/0/0 interface is shut or not.
