Powershell Script to backup 2960 Stack Full Configuration
Azuriste
Hello ,
Im looking for a powershell script to backup my 2960 switch Stack configuration .
I prefer follow a bestpractices.
omz
Powershell ... really? :) I prefer using Python but .. anyhow have a look at this post.
https://www.sherweb.com/blog/fun-with-powershell-plink-cisco-ios-and-powershell/
I think PS is complicated here .could you let me know how with perl please ?
Sorry, I don't know perl :)
**BANTER Start** showing your age ;) **BANTER End**
But have look here -
https://thwack.solarwinds.com/thread/19748
If you fancy giving Python a go.
Prerequisites:
- Install Python 2.7, Paramiko and getpass
import paramiko
import time
import getpass
import os
import sys
#IP = '1.1.1.2'
#USER = raw_input("Username : ")
#PASS = getpass.getpass("Password : ")
#ENABLE = getpass.getpass("Enable : ")
# ONLY FOR TESTING HARD CODE. UNCOMMENT ABOVE AND DELETE  BELOW AFTER TESTING
IP = '1.1.1.2'
USER = 'cisco'
PASS = 'cisco123'
ENABLE = 'cisco123'
ssh = paramiko.SSHClient()
ssh.set_missing_host_key_policy(paramiko.AutoAddPolicy())
ssh.connect(IP, port=22, username=USER, password=PASS, look_for_keys=False,allow_agent=False)
remote = ssh.invoke_shell()
remote.send('term len 0\n')
remote.send('enable\n')
remote.send('%s\n' % ENABLE)
time.sleep(1)
remote.send('sh run\n')
time.sleep(10)
output = remote.recv(65000)
print output
timestr = time.strftime("%Y%m%d-%H%M")
with open('{}-{}.txt'.format(IP, timestr), 'a') as config:
    config.write(output)
Just for your info you may want to look at Netmiko (written by the same guy) which uses Paramiko but takes out some of the lower level stuff for managing network devices.
So your code in Netmiko would be -
from netmiko import ConnectHandler
swp = ConnectHandler(device_type='cisco_ios', ip=IP, username=USER, password=PASS, secret=ENABLE)
swp.enable()
output = swp.send_command('sh run')
print output
Jon
