PPP Authentication
walu
Hi Together,
i like to use the "ppp chap hostname feature" for Authentication with an Username different than the Routers Name. The first implementations with just one dialer Interface works fine on a Cisco 836.
But now i have the Problem that if a router has a already an dialer Interface used for WAN backup with the "dialer watch" feature in this case the authentication for incoming calls are via the routers name.
If we configure the "ppp chap hostname" directly on the BRI Interface than its working again. But than the Backup doesn´t work anymore.
Here are extracts of the Configurtion.
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 2
dialer pool-member 3
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn tei-negotiation preserve
ppp authentication chap
interface Dialer0
description *** Dialer for Outband ***
ip address negotiated
encapsulation ppp
dialer pool 2
dialer remote-name dsd-rt04
ppp authentication chap callin
ppp chap hostname smc_callin
ppp chap password 7 xxxxxxx
interface Dialer1
description *** Dialer for Backup ***
encapsulation ppp
dialer pool 3
dialer remote-name hkd_Z38_R1
dialer idle-timeout 300
dialer string 021173779750
dialer watch-group 2
dialer-group 2
ppp chap hostname hkd01014
Has anybody experience with the issue.
Thank you for any help.
owillins
Level 6
Level 6
The document has more information on PPP Authentication Using the ppp chap hostname.
http://www.cisco.com/warp/public/131/ppp_callin_hostname.html
