08-01-2021 02:12 AM
Hi All
Anyone knows , is it possible to log ppp ip assignment to syslog ? (without using debug command)
I mean logging ip assignment over the ppp phases from local pool to users via logging levels (0-7) in BRAS(ASR Router) without using debug command .
(what user has been assigned what IP address)
08-01-2021 03:57 AM
We are not sure what is this device model and IOS Code running here - But in most cases, it's hard to capture the Logging the king of requirement.
but if you have Radius or any other system in place can be done :
08-01-2021 05:57 AM
Thanks alot for your reply.
The problem is , we dont have access to radius server actually.
But we need the users login informations specially IP address that they have been given via syslog.
Any solution do you suggest ?
08-01-2021 06:01 AM
Also the device model is ASR1002-X
and the IOS is : asr1002x-universalk9.03.13.03.S.154-3.S3-ext.SPA.bin
08-02-2021 12:45 AM
How about snmp ?
Is it possible to generate trap on ppp ip assignment ?
08-02-2021 02:47 AM
Not sure never tried it, SNMP walk may get connected user information, need to look at the document.
