PPP Multilink Limitations
snagelipphone
We are looking ad bonding 8 T1s using a PPP Multilink on either a 2800 or 3800 series router. Is there a limitation on the number of T1s I can bond together and is there a router limitation? For example can a 2821 router only support 6 T1s bonded while a 2851 supports 8-10 and a 3825 support 12-15?
Any input would be appreciated.
THANKS in advance.
Scott
paolo bevilacqua
Generally there is a limit of 12 circuits per bundle, even on bigger platforms that the ones you mentioned.
