PPP Multilink over T1 on 1760
dmongrain
Hi all,
I am configuring 2 1760 connected back-to-back using a single T1. In order to support VoIP, I want to enable PPP multilink on the T1 for fragmentation. However when I enable PPP multilink on the T1 serial interface, the link goes down and the serial interface reports framing errors and resets. If I do not enable multilink the link is clean.
I searched the documentation and I cannot find anywhere that this setup is not supported. I am running the same setup between 2811 without errors.
Is there something I am missing?
version 12.3
hostname pvgtwy4a
boot-start-marker
boot-end-marker
tdm clock T1 0/0 data import onboard internal
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
controller T1 0/0
framing esf
linecode b8zs
cablelength short 133
channel-group 0 timeslots 1-24 speed 64
interface Multilink1
mtu 2000
ip address 10.255.255.2 255.255.255.252
max-reserved-bandwidth 100
ip route-cache flow
ip tcp header-compression iphc-format
ppp multilink
ppp multilink fragment delay 5
ppp multilink interleave
ppp multilink group 1
ppp multilink mrru local 2000
ppp multilink mrru remote 2000
ip rtp header-compression iphc-format
interface FastEthernet0/0
speed auto
full-duplex
interface Serial0/0:0
ip address 10.255.255.6 255.255.255.252
encapsulation ppp
ppp multilink
ip classless
no ip http server
control-plan
version 12.3
hostname pvgtwy4b
boot-start-marker
boot-end-marker
tdm clock T1 0/0 both export line
no mmi pvc
voice-card 0
no aaa new-model
ip subnet-zero
ip cef
controller T1 0/0
framing esf
linecode b8zs
mtu 2000
ip address 10.255.255.1 255.255.255.252
ip route-cache flow
ppp multilink
ip address 192.168.0.1 255.255.255.0
speed auto
full-duplex
ip address 10.255.255.5 255.255.255.252
encapsulation ppp
ppp multilink
ip classless
no ip http server
control-plane
5 Replies 5
paolo bevilacqua
Can be an IOS anomaly issue.
Upgrade to latest 12.3 that is like 40 or so, remove all what not essential under multilink interface and try again.
I have upgraded already to the latest release of the train 12.3(11)T. I was running 12.3(11)T and upgraded to 12.3(11)T11 with the same result.
I get this error as soon as I enable PPP multilink on the serial interface, even if I do not specify which PPP multilink group...
Can you try 12.4(3j) that is the most stable release as of today ?
Paolo,
I'm curious about your suggestion. Since within a mainline release, changes are supposed to be limited to bug fixes, wouldn't, in theory, the very latest be the most stable?
Your original post would also seem to endorse using the latest.
Joseph W. Doherty
BTW: depending on how much of the T-1's bandwidth you have, fragmention to support voice might be unnecessary.
