PPPoA Migration
ixholla69
We're a small DSL provider and are looking to migrate from route-bridged PPPoA dsl over to PPPoE. I would like to run both in Parrallel on my 7200VXR and gradually migrate them over but have a couple questions.
#1 What is ganed by migrating over from PPPoA to PPPoE and advantages if any?
#2 Can you run both in Parrallel? Can PPPoA and PPPoE even exist on the same router?
#3 Are there any disadvantages from running PPPoE it seems to be the norm these days.
#4 IPv6 advantages? Our company although small is taking IPv6 very seriously.
#5 Caveats or Problems?
Thank you!
Frederic Vanderbecq
here are some answers to your questions:
PPPoE induces slightly less overhead than PPPoA (except if you are running PPPoEoA) and does not require any ATM connections. It is thus easier to deploy.
Yes, you can have both running at the same time. The only thing to be careful with is if you are running PPPoA and PPPoEoA (PPPoE over ATM) towards a specific customer, those would require 2 separate PVCs I believe.
At the moment, using IPv6 only prepares your router for "the future". There are no yet any specific bonus to implement it apart being ready.
Anything is possible ;-)
