hy,
I have a intranet that is base on a 1x router 2611xm, 1x switch 2950, the net is ok, it's working but my problem half security, 1/2 pppoe conection and 1/2 inter-vlan routing
I will paste the config from router here to talk direct on.
Building configuration...
Current configuration : 5608 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname R1-ALFA
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 10
enable secret 5 *********************
aaa new-model
aaa authentication login local_auth local
aaa session-id common
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
login block-for 180 attempts 3 within 180
username *************** password 7 ****************
archive
log config
hidekeys
ip ssh port ****** rotary ****
interface FastEthernet0/0
description The interface that talk with ISP
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 12
no cdp enable
no mop enabled
interface FastEthernet0/1
description The interface that let you to play inside
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1.19
description The vlan from devices like printes (static)
encapsulation dot1Q 19
ip address 172.31.245.145 255.255.255.240
no cdp enable
interface FastEthernet0/1.29
description The vlan for something I don't know
encapsulation dot1Q 29
ip address 172.16.0.1 255.255.255.240
no cdp enable
interface FastEthernet0/1.55
description The vlan for play on net
encapsulation dot1Q 55
ip address 172.16.30.161 255.255.255.240
ip nat inside
no cdp enable
interface Dialer12
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 12
dialer idle-timeout 0
dialer persistent
dialer-group 12
no cdp enable
ppp authentication pap callin
ppp pap sent-username *********** password 7 **********
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
no ip http server
ip http secure-server
ip dns server
ip nat inside source list 15 interface Dialer12 overload
ip access-list extended fohSSH
deny tcp any any eq 22
permit tcp any any eq *****
access-list 15 permit 172.16.30.160 0.0.0.15
dialer-list 12 protocol ip permit
no cdp run
control-plane
banner motd ^CIf you're not the Admin get out!!^C
line con 0
exec-timeout 180 0
login authentication local_auth
line aux 0
line vty 0 4
access-class fohSSH in
rotary ****
transport input ssh
line vty 5 9
rotary 12
transport input ssh
line vty 10
rotary 12
transport input ssh
line vty 11 15
rotary 12
transport input ssh
end
So this is the config of the router, Now I want to add a layer of security (I don't have firewall, so I use what i have a router :)) ) now I want to add few acl rules.
The goal is:
--> to don't let outside(the external internet) to can scan, access, sent packets on the ports like 23,22,161, etc
--> private ips from outside to enter in router
--> to block ports from inside to outside
--> to block all other ports
--> where to set future acl on a dialer, subinterfaces or on interfaces directly (first I tried on the dialer after that I was unanable to access the internet)
If you have others ideas I can't wait to hear...
I made some rules hope are ok, I will paste down
ip access-list extended NotAllowIpsToBeUseed
remark those ip are use to Block Spoof/Malicious packets
deny ip 224.0.0.0 31.255.255.255 any
deny ip 10.0.0.0 0.255.255.255 any
deny ip 192.168.0.0 0.0.255.255 any
deny ip 127.0.0.0 0.255.255.255 any
deny ip 172.16.0.0 0.0.255.255 any
ip access-list extended NotAllowToInside
remark this ACL don't allow to access well know ports to attack the internal network
deny tcp any any eq echo
deny tcp any any eq discard
deny tcp any any eq daytime
deny tcp any any eq chargen
deny tcp any any eq telnet
deny tcp any any eq finger
deny tcp any any eq 3389
deny tcp any any eq 161
deny tcp any any eq www
deny tcp any any eq 37
deny tcp any any eq 69
deny tcp any any eq ftp-data
permit tcp any 172.16.30.160 0.0.0.15 eq 443
basically, you can consolidate everything into one access list and apply that outbound to the dialer interface. The important part is the last line, which should allow Internet access:
ip access-list extended PROTECT_ACL
--> permit ip 172.16.30.160 0.0.0.15 any
interface Dialer12
--> ip access-group PROTECT_ACL out
Hello
Two possible security features if supported my assist here-
CBAC or ZBFW, Attached are examples of both.
there are three sub interface for your LAN
there is one dialer interface
for all must config the dialer list with permit any
you can config ACL out the dialer interface
you can config ACL in on each on your three LAN sub interface
