pppoe configuration problem
CSCO10825585
Hello!
I have this configuration in my Cisco827.
I have managed to go out to Internet to some pages but it does not go out for great others.
If I remove the access list 1 does not go out at all.
In what interface is this access list applied?
It can be a problem of safety or of mtu ...?
Thanks.
version 12.2
no service pad
hostname Router
ip subnet-zero
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
pvc 8/32
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname adslppp@telefonicanetpa
ppp chap password 0 adslppp
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 deny any
line con 0
password indartsu99
stopbits 1
line vty 0
access-class 1 in
exec-timeout 120 0
password xxx
login
line vty 1 4
password xxx
login
scheduler max-task-time 5000
end
Javier Calleja.
5 Replies 5
stephen.stack
Level 4
Level 4
HI Javier,
Just wondering if you have a proplem displaying webpages like Hotmail.com.
Try adding the following command under ethernet0
ip tcp adjust-mss 1452
This should fix your issue. If this helps.. please rate post.
PS you may want to remove your passwords from yuor config before posting it on a public forum. (just a tip :) )
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Hello Stephen!
Thanks for your recommendations.
The router works perfectly with your solution.
The message " dynamic configuration problem " I have answered it after creating this one since I have not seen it.
On the other hand I have a doubt, and have learned that in order that an access list should be executed it is necessary to put in the interface access-group and n ?.
Is not it necessary to do it?..
Thanks for everything.
Happy new year.
Javier Calleja.
Hi Javier,
I just noticed the duplicate post too. We'll stick with this thread.
Glad to hear it fixed the issue. It is a very common issue with DSL and Cisco routers.
In relation to the last part of you message...
If you are talking about access-list 1, this access-list is realted to the NAT statment.
'Source List 1' Refers to access-ist 1. This access-list tells NAT which IP address range is allowed to partake in NAT translations.
Access-lists do not always have to be bound to interfaces. In fact they are bound more to routing policies, QOS statements, and the likes more than restrictions for traffic on interfaces.
One more tip for you. Install SDM on your PC and setup and configure the Cisco IOS firewall for security.
Have a happy new year.
Don't forget to rate posts :)
Stephen
Hello Stephen!
I?m afraid that I cannot install the SDM because I have a cisco 800 series (827).
Can i use extended access list with Nat as the standard?
You can use an extended Access-list.
Cisco SDM (Security Device Manager) will work with the Cisco 827. you can download it from here
http://www.cisco.com/en/US/products/sw/secursw/ps5318/index.html
and just click on the 'download software' link on the right side of the page. install it on your PC only. and get it talking to your 827.
Stephen
