PPPoE create bba subblock failed
usslindstrom
Trying to issue the pppoe enable command on a fastethernet port on my 1841, and continually get this error message:
PPPoE create bba subblock failed.
What does it mean? I can't find ANYTHING on Cisco's site, or even google on it.
PPPoE will be for an ADSL connection.
Whatever information you guys can help with would be greatly appreciated.
paolo bevilacqua
Ios version ? config ?
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(17), RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Sep-07 14:45 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Oki_1841 uptime is 11 minutes
System restarted at 20:46:13 JST Thu Mar 27 2008
System image file is "flash:c1841-ipbase-mz.124-17.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX1146Z0EV
2 FastEthernet interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
interface FastEthernet0/0
description Internal_Network
no ip address
ip nat inside
speed 100
full-duplex
bridge-group 1
interface FastEthernet0/1
description DMZ_Network
no ip address
ip nat inside
speed 100
full-duplex
bridge-group 1
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
no snmp trap link-status
pvc 0/32
pppoe-client dial-pool-number 1
interface Dialer1
description ADSL_WAN_Dialer
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nbar protocol-discovery
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 7 xxx
ppp pap sent-username xxx password 7 xxx
ppp ipcp route default
interface BVI1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
In the config here, I still have the BVI enabled - since I'm still trying to connect to my ISP via my Wic-1ADSL... But since I was having issues, I tried to just go through the ethernet port - to my isp provided modem...
And that's when I get the pppoe create subblock failed.
Even after I completely delete all the config under the Ethernet ports.
