Join Customer Connection to register!
2682
canero
Beginner
PPPoE Dialer in VRF disables IP address negotiation 887VA
We are trying to take ADSL interface into another VRF i.e (ip vrf forwarding VRF2 under dialer interface), the ip address negotiated command disappears, and although the dialer interface becomes up-up state, the adsl interface does not get an IP address dynamically.
Tried:
1) to reenter ip address negotiated again after changing the vrf of the interface, still the dialer interface shows "no ip address" under configuration
2) ppp ipcp accept-address again does not work.
How can we solve this problem?
Thanks in Advance,
Best Regards,
the IOS version:c880data-universalk9-mz.151-2.T1.bin
1 REPLY 1
mavespig
Participant
I'd suggest to enable
-deb ppp nego
-deb dialer
Then follow these steps:
conf t
int dia 1
 shut
 no ip address nego
 ip vrf forwarding
 ip address nego
 no shut
After that, (if it does not work), collect the logs and a show run.
Marco
