pppoe on 2621
bbach1961
I'm trying to use a 2621 for a dsl circuit and I'd like it to do the pppoe. I only know enough to be dangerous. When I try to configure pppoe, it looks like the IOS I have does not have pppoe available:
Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#vpdn-group 1
Router(config-vpdn)#request-dialin
Router(config-vpdn-req-in)#protocol pppoe
% Invalid input detected at '^' marker.
Router(config-vpdn-req-in)#protocol ?
l2f Use L2F
l2tp Use L2TP
Is this possible or is there another way to configure pppoe? Here is the beginning of show ver:
Router#show ver
IOS (tm) C2600 Software (C2600-IK2O3S-M), Version 12.1(27b), RELEASE SOFTWARE (fc1)
Thanks. -- Bud
paolo bevilacqua
No, you IOS is too old. Once you upgrade, you won;t need even the vpdn stuff.
