PPPoE server - ghost sessions
dominiaz
I have a problem with pppoe server ghosts sessions:
C        172.16.1.116 is directly connected, Virtual-Access2.7
                      is directly connected, Virtual-Access2.6
                      is directly connected, Virtual-Access2.5
                      is directly connected, Virtual-Access2.4
                      is directly connected, Virtual-Access2.3
                      is directly connected, Virtual-Access2.2
                      is directly connected, Virtual-Access2.1
PPPoE server configuration:
bba-group pppoe global
 virtual-template 1
 sessions per-vc limit 32000
 sessions per-mac limit 32000
 sessions per-vlan limit 32000 inner 32000
 sessions auto cleanup
interface Virtual-Template1
 mtu 1492
 ip unnumbered Loopback0
 ip nat inside
 ip tcp adjust-mss 1452
 no logging event link-status
 no peer default ip address
 keepalive 30
 ppp mtu adaptive
 ppp authentication chap ms-chap-v2
What excatly you issue here?
MHM
dominiaz
Why 1 client with 1 IP - 172.16.1.116 is connected to 7 Virtual-Access interfaces at 1 time?
I will check it'
You are right you must see only one VCI.
MHM
Hello
what makes you think these are ghost interfaces - do you have a virtual profile if so these VT interface could be multiple user connections?
Kind Regards
Paul
