06-07-2017 11:09 PM - edited 03-05-2019 08:40 AM
Does Cisco ASR 920 support PPPoE server on either BDI or Phy interface?
I tried to find refer DOC but no able to find where specifically mention support or not support.
I can configure and client can connect but routing was not working. I also can not do show interface vi2.x .
06-07-2017 11:23 PM
PPPoE server is NOT supported on BDI (check the link below). Also, the BDI or the VI used by the PPPoE client should not be used for routing.
What are you trying to accomplish ?
Restrictions for PPPoE on BDI
http://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/ce/b_layer2_ASR920/pppoe-on-bridge-domain-interface.html#GUID-75ED588D-14F1-4F52-BF75-47DFFD5F0459
06-09-2017 02:13 AM
I am trying to enable PPPoE server on my router, ASR920. it can be Physical or BDI Interface.
As you mentioned, BDI does not support as PPPoE Server interface.
How about Physical interface ? like G0/0/0 or G0/0/1 ?
06-09-2017 05:50 AM
physical interface should work. Below is a sample configuration (authentication might differ from your setup):
bba-group pppoe global
virtual-template 1
interface Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
interface GigabitEthernet0/1
description To-PPPoE-Client
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
negotiation auto
pppoe enable group global
interface Virtual-Template1
ip unnumbered Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
no logging event link-status
no peer default ip address
no snmp trap link-status
no keepalive
ppp authentication chap callin
