PPPOE server with NAT to public IP
ahmedabdelbaqi
Hello Dears
I want to configure cisco router as pppoe server and connect it to internet via public IP ..
I configured the router with the below configuration but when I configure nat in the interfaces I dont get internet in pppoe clients
username a password 0 a
redundancy
bba-group pppoe TEST
 virtual-template 1
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 pppoe enable group TEST
interface FastEthernet0/1
 ip address x.x.x.x x.x.x.x ( public IP )
 duplex auto
 speed auto
interface Virtual-Template1
 mtu 1492
 ip unnumbered Loopback0
 peer default ip address pool PPPOE
 ppp authentication chap callin
ip local pool PPPOE 192.168.44.2 192.168.44.100
Martin Hruby
Hello
Make sure that your Cisco router (PPPoE server) has a default route towards the Internet and that your PPPoE clients receive a default route (over IPCP or static configuration). Then configure NAT:
access-list 10 permit 192.168.44.0 0.0.0.127
 ip nat inside
 ip nat outside
ip nat inside source list 10 interface FastEthernet0/1 overload
I think you're also missing a vpdn enable command from your Cisco router.
Best regards,
Martin
Martin Hruby
Hello
 ip nat inside
 ip nat outside
Best regards,
Martin
