06-05-2017 07:02 PM - edited 03-05-2019 08:39 AM
Hi everyone..
i have a (Cisco router and 50 PCs), i wanna to configure a pppoe server on my router and create users in pppoe server for my PCs.
can anyone help me how to configure pppoe server and how create the users to the PCs?
06-05-2017 07:21 PM
What sort of router do you have?
To confirm; you want the users to use PPPoE to connect to your router, as opposed to having the router connect via PPPoE to your ISP?
06-06-2017 01:57 AM
the router is 2800
the connection between the router and the ISP is via static route, yes i wanna the PCs connect to the router via pppoe.
06-06-2017 03:40 PM
Something like:
aaa new-model
aaa authentication ppp default local
ip address-pool local
vpdn enable
vpdn logging
vpdn logging local
vpdn session-limit 300
vpdn-group pppoe
accept-dialin
protocol pppoe
virtual-template 1
virtual-template 1 pre-clone 50
interface Gigabit x/y/z
description Interface facing clients
pppoe enable
interface Virtual-Template1
description PPPoE users get a Virtual-Access interface cloned from this
ip unnumbered Gigabit x/y/z (above interface)
ip mtu 1492
no peer default ip address <<-- this will need changing to use below
ppp authentication pap
ppp timeout idle 14400 either
ip local pool pppoe a.b.c.d a.b.c.z
06-07-2017 02:23 PM
dear Philip D'Ath
do you have a link or documentation talking about the configuration?
I'm very thankful for helping me.
06-07-2017 02:50 PM
No. Also note you will need a "data" licence (now called an "AX" licence) to make it work.
