PPTP Client Authentication to ISP
aburrows
My ISP has just implemented a new network on the cable infrastructure which uses a PPTP authentication method.  It works on my Cisco RVS4000 router as there is an option to set PPTP as the WAN type.  The only trouble with the RVS4000 is that the performance is very poor, hence I am trying to get it working with a Cisco 1921.  I have looked high and low and I cannot find an sample of a Cisco router functioning as PPTP client to a ISP.  Does anyone have an example of this please.  Enclosed is the screen shot of my Cisco RVS400 with the options etc.
Many Thanks
Alex
Abzal
Level 7
Level 7
Try this link:
https://learningnetwork.cisco.com/docs/DOC-4212
If you need help just ask.
Best regards,
Abzal
Thanks for the help.  In the end I had 95 percent correct.  After debugging it was a chap problem.
