12-01-2021 02:39 PM - edited 12-01-2021 02:40 PM
We're migrating from an RV325 to a ISR 1111-4P router. We currently have PPTP VPN server working on the RV325.
We're using 17.5.1 IOS
Router#show version Cisco IOS XE Software, Version 17.05.01a Cisco IOS Software [Bengaluru], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.5.1a, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2021 by Cisco Systems, Inc. Compiled Sun 11-Apr-21 16:54 by mcpre
I tried to setup PPTP VPN server on the ISR 1111-4P and I get an error during configuration:
Router(config-vpdn)#accept-dialin Router(config-vpdn-acc-in)#protocol pptp ^ % Invalid input detected at '^' marker. Router(config-vpdn-acc-in)#protocol ? any Use any protocol l2tp Use L2TP
Is PPTP still supported on the ISR 1100 series routers? I know that L2TP/IPSEC is the recommended way to go. I know that vendors like Apple have dropped support for PPTP entirely. But I wanted to get PPTP working for now as I do the migration.
Thx!
Solved! Go to Solution.
12-02-2021 02:04 PM
as per the datasheet i do not see that supports :
12-01-2021 03:11 PM
follow
12-02-2021 02:04 PM
12-02-2021 02:22 PM
as far as I recall, support for PPTP is being phased out mainly because it is considered unsafe (see the link below).
It has been around since Windows 95 (if you are old enough to remember that).
The RV325 is end of life as well for a couple of years. So you are basically dealing with an evolution in hard and software standards.
