Precedence of PBR next-hop over direct connected route
lcarrau
Hello!
The main objective is to redirect the traffic of all VLANs to an inter-vlan Firewall.
Can I do that with PBR?
The idea is to forward all packets to the firewall without looking on the routing table (Routing table override).
Configuration would be like that:
ip access-list standard acl-anyip
  permit any
interface Vlan10
   description Network to firewall
   ip address 172.16.0.1 255.255.255.0
   ip policy route-map ivsec
interface Vlan100
   ip address 172.16.1.1 255.255.255.0
interface Vlan200
   ip address 172.16.2.1 255.255.255.0
route-map ivsec permit 10
  match ip address acl-anyip
  set ip next-hop 172.16.0.2  !Firewall IP Address
Please do not be too strict about the config... I took it direct out of my head as an idea.
Thanks a lot in advanced.
Lanello Carrau
Switch# show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.06.02.E RELEASE SOFTWARE (fc1)
2 Accepted Solutions
Gaurav Gambhir
Yes PBR is the feature to bypass routing table and force the traffic to a different next hop.
your config logic also looks good. here is a link for PBR on 4500 as well
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/pbroute.pdf
Filip Knezevic
Hi Lanello,
Yes, this should work. Tried in lab:
Extended IP access list ALL_TRAFFIC
10 permit ip any any
R2#sh route-map
route-map ALL_TRAFFIC, permit, sequence 10
Match clauses:
ip address (access-lists): ALL_TRAFFIC
Set clauses:
ip next-hop 10.10.23.2
Policy routing matches: 18 packets, 1290 bytes
R2#
interface FastEthernet1/1.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip policy route-map ALL_TRAFFIC
end
R2(config-subif)#
ip route 0.0.0.0 0.0.0.0 10.10.12.2
Trace from a 'PC' without route-map:
PC#trace 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
1 10.10.10.1 76 msec 32 msec 28 msec
2 10.10.12.2 28 msec 48 msec 32 msec
3 10.21.10.2 40 msec 52 msec 44 msec
PC#
Trace from a 'PC' with route-map applied:
PC#trace 8.8.8.8
1 10.10.10.1 96 msec 16 msec 28 msec
2 10.10.23.2 64 msec 60 msec 60 msec
3 10.20.10.1 72 msec 60 msec 68 msec
PC#
Gaurav Gambhir
Deepak Kumar
You can do the same with PBR and PBR will precedence over the routing table. Keep in mind that all source and destination networks must match in the ACL "acl-anyip" otherwise nonmatching traffic will route through the normal routing table.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Filip Knezevic
Hi Lanello,
R2#sh route-map
Match clauses:
Set clauses:
R2#
end
R2(config-subif)#
PC#trace 8.8.8.8
PC#
PC#trace 8.8.8.8
PC#
