pri-group command not available
atosorigin
I would like to know why the pri-group command is not available under the controller xx submenu of my 2600XM router. It is running the following IOS c2600-advipservicesk9-mz.123-26.bin and have a VWIC-1MFT-G703 card.
Thanks a lot for your help.
paolo bevilacqua
Hi, for data only pri on the vwic, you can try with an non-voice image, else the recommended card is nm-xce1/t1.
I tried first with a ipbase image but I've got the same result. Moreover the pri-group command is available with the same card on 1841 platform.
The 1841 is very different. On the 2600 the only way to have data pri is the nm mentioned, or a the vwic in a nm-hdv with codecs.
