PRI Provisioning
dennylester
I have a Cisco 2811 with a NM-2CE1T1-PRI network module. We plan to use this for backups via demand dial routing to remote Cisco routers with BRI cards.
I am placing my PRI order and was sent this provisioning form to fill out. It seems very PBX specific so I need a little help.
General Provisioning Information
Framing: I put B8ZS/ESF
Digits to complete call (3/4/10): I put 10
DS1 Specific Provisioning Information
Out pulse type (DTMF or Dial Pulse): ??
Supervision Signaling: (E&M or Other): ??
In & Out Start Signaling (Immediate or Wink): ??
Outgoing Trunk Selection: ???
Dial Tone (PBX Provided or Carrier Provided): ??
Thank you in advance,
Denny
jim_berlow
Level 3
Level 3
The framing and digits sound fine. I would ask your provider about the other parameters - I don't think they really pertain to what your doing. This is probably a generic form that is provided for all PRI's and this info would be needed if you were connecting it to your PBX.
Thank you for clarifying this. Hopefully they will know how to configure it on their end.
Now I need to find some articles on how to configure it on my end. :-)
Denny
paolo bevilacqua
Jim is correct, the "DS1 specific parameters" would only apply for a CAS circuit, but wisely you're requesting PRI.
