Problem with 1841
vitorssouza
I m having a problem with my cisco 1841.
From the router i can ping external ip(4.2.2.2 or 187.103.200.1). but a user from vlan 11 can ping router wan interface 187.103.200.2 and default gw 172.25.11.1, but can't ping external ip.
Hi Vitor
Can you remove ip nat inside from Physical interface & configure the same one under all subinteface.
Can you post output of sh ver (IOS Ver.)
Chetan Kumar
6 Replies 6
Reza Sharifi
Hi Vitor,
Looking at your config,  is vlan 11 supposed be actually a /30 subnet or is it a typo?
interface FastEthernet0/1.11
description qi
encapsulation dot1Q 11
ip address 172.25.11.1 255.255.255.252
Reza
Reza,
it is right, because for this vlan there is only 1 valid ip, for the user.
wang baojun
Vitor,
the config seem no problem ,you can try done the following operation.
description qi
ip nat inside
Wang,
Still not working, i think  it is something on access-list.
Hi Vitor
Chetan Kumar
Thanks!!!!!
