Problem with BGP adjacency
Hello community,
I am trying several BGP configurations in a GNS3 lab and i have some issues.
BGP adjacencies do not seem to work, as i can not ping several ip address in the network and also they do not exist as BGP entries in the routing tables in some devices. To be more specific, i can not ping the loopback 0 in R4 from R3 and R2.
I do not know what i do wrong, but i do not think i miss something.
I am uploading the topology in GNS3 and also some basic configurations i have done in the routers.
Any help is appreciated.
Thanks in advance.
Harold Ritter
Hi @sakatzidisgiwrgos ,
R2 and R4 can't reach
3.3.3.3/32
as the
next hop
received from R1 is not reachable. You need to configure the following on R1, so that it changes the
next hop
to itself:
router bgp 12
neighbor 10.1.1.99 next-hop-self all
neighbor 192.168.12.2 next-hop-self all
The other thing is that
12.12.12.0/24
is not advertised from R1 to R2, as routes received from an iBGP neighbor can't be advertised to another iBGP neighbor, unless you make R1 a route reflector as follow:
router bgp 12
neighbor 10.1.1.99 route-reflector-client
neighbor 192.168.12.2 route-reflector-client
8 Replies 8
Your bgp neighbor is not reachable
Run
ospf
between four routers and check again.
Ah ok. So BGP works only when
OSPF
is also configured ?
Bgp not need
ospf
but need rechability' you must ping IP you use in
bgp neighbor
command.
I Suggest use
ospf
to make each router reachable to each other.
There is no need for
ospf
in your scenario, as all your bgp sessions use directly connected addresses.
two way he can solve issue
as you mention using
next-hop
self in R1
or using OSPF make
next-hop of 3.3.3.3
is reachable by other routers
That is absolutely right @MHM Cisco World .
If
ospf
is not used the
next-hop-self all
needs to be configured on R1, so that the
next hop
is changed for reflected iBGP routes as well.
thanks a lot
Harold Ritter
3.3.3.3/32
as the
next hop
next hop
to itself:
router bgp 12
12.12.12.0/24
router bgp 12
