problem with dhcp client
chmod700-r
hi, i have a cisco soho 91.
i have a problem with client dhcp: on e0 of my router there is my lan and e0 have a static ip (192.168.2.0), WAN port must have dinamic ip assigned by ISP. this is my configuration:
Router#sh run
Building configuration...
Current configuration : 3402 bytes
version 12.3
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname Router
no logging buffered
logging rate-limit 500
enable secret 5 xxxxxxxxxxxxxxxxxxxx
username Router password 7 xxxxxxxxxxx
no aaa new-model
ip subnet-zero
no ip source-route
ip tcp selective-ack
ip tcp window-size 2144
ip tcp synwait-time 50
no ip bootp server
ip cef
interface Ethernet0
ip address 192.168.2.1 255.255.255.0
ip access-group 130 in
ip nat inside
no cdp enable
interface Ethernet1
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip nat outside
duplex auto
no cdp enable
ip nat inside source list PERMISSIONI_NAT interface Ethernet1 overload
ip classless
no ip forward-protocol udp bootps
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
no ip http server
no ip http secure-server
ip access-list standard PERMISSIONI_NAT
permit 192.168.2.0 0.0.0.255
but i don't recive any ip.
now post result of debug dhcp det
chmod700-r
*Mar 1 00:40:40.267: DHCP: Waiting for 10 seconds on interface Ethernet1
*Mar 1 00:40:44.619: DHCP: QScan: Purging entry
*Mar 1 00:40:44.619: DHCP: deleting entry 814549E4 0.0.0.0 from list
*Mar 1 00:40:44.619: Temp IP addr: 0.0.0.0 for peer on Interface: unknown
*Mar 1 00:40:44.619: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:44.619: DHCP Lease server: 0.0.0.0, state: 8 Purging
*Mar 1 00:40:44.619: DHCP transaction id: 25FE
*Mar 1 00:40:44.619: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:44.619: No timer running
*Mar 1 00:40:44.619: Retry count: 0 Client-ID:
*Mar 1 00:40:44.619: Hostname: Router
*Mar 1 00:40:50.267: DHCP: Try 3 to acquire address for Ethernet1
*Mar 1 00:40:50.267: DHCP: allocate request
*Mar 1 00:40:50.267: DHCP: zapping entry in DHC_PURGING state for Et1
*Mar 1 00:40:50.267: DHCP: new entry. add to queue
*Mar 1 00:40:50.271: DHCP: SDiscover attempt # 1 for entry:
*Mar 1 00:40:50.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:50.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:50.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:50.271: DHCP transaction id: 2600
*Mar 1 00:40:50.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:50.271: Next timer fires after: 00:00:03
*Mar 1 00:40:50.271: Retry count: 1 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:50.271: Hostname: Router
*Mar 1 00:40:50.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:50.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:50.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:53.271: DHCP: SDiscover attempt # 2 for entry:
*Mar 1 00:40:53.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:53.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:53.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:53.271: DHCP transaction id: 2600
*Mar 1 00:40:53.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:53.271: Next timer fires after: 00:00:03
*Mar 1 00:40:53.271: Retry count: 2 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:53.271: Hostname: Router
*Mar 1 00:40:53.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:53.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:53.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:56.271: DHCP: SDiscover attempt # 3 for entry:
*Mar 1 00:40:56.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:56.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:56.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:56.271: DHCP transaction id: 2600
*Mar 1 00:40:56.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:56.271: Next timer fires after: 00:00:03
*Mar 1 00:40:56.271: Retry count: 3 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:56.271: Hostname: Router
*Mar 1 00:40:56.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:56.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:56.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:59.271: DHCP: QScan: Timed out Selecting state
*Mar 1 00:41:10.267: DHCP: QScan: Purging entry
*Mar 1 00:41:10.267: DHCP: deleting entry 8147AABC 0.0.0.0 from list
*Mar 1 00:41:10.267: Temp IP addr: 0.0.0.0 for peer on Interface: unknown
*Mar 1 00:41:10.267: Temp sub net mask: 0.0.0.0
*Mar 1 00:41:10.267: DHCP Lease server: 0.0.0.0, state: 8 Purging
*Mar 1 00:41:10.267: DHCP transaction id: 25FF
*Mar 1 00:41:10.267: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:41:10.267: No timer running
*Mar 1 00:41:10.267: Retry count: 0 Client-ID:
*Mar 1 00:41:10.267: Hostname: Router%Unknown DHCP problem.. No allocation possible
what is the problem?
there is a mistake in my configuration?
what kind of device is upstream from your E1 interface? (i.e. cable modem? adsl modem?).
Depending on what device it is have your power-cycled that upstream device? Some cable devices will cache a single MAC Address and if you switch downstream devices, the newly attached device will not receive an IP if the cable device has not been power cycled.
after E1 interfaces there are 5 wireless antennas (5GHz) and after there is a dhcp server.
