Problem with DSL connection.
leofalconi
Hello people,
I have a problem with the ADSL connection on C887VA-K9, 15.4(3)M6a.
The configuration of ATM and Dialer is this:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface Dialer2
 mtu 1492
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 2
 dialer-group 1
 ppp chap hostname W14201532648
 ppp chap password 7 xxxx
 ppp pap sent-username W14201532648 password 7 xxxx
 crypto map ROE
From the show ip int brief command I see that the ATM int is UP/UP while the Virtual Acces 4 is UP/DOWN.
I have typed the "debug ppp authentication" and "debug ppp negotiation" and I have attacched the files.
I think there is a problem with LCP phase, and the problem is provider side.
What do you think?
Thank you,
Leonardo
Hello Leonardo,
you are running a VPN (crypto map ROE) ? Can you post the full config ? Here is a sample configuration for a typical ADSL/PPPoE link on an 887:
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname
boot-start-marker
boot-end-marker
logging buffered 65535
logging console informational
enable secret
no aaa new-model
memory-size iomem 10
clock timezone ACST 9 30
clock summer-time ACST recurring first Sun Oct 2:00 first Sun Apr 2:00
no ip source-route
ip dhcp excluded-address 192.168.0.0 192.168.0.10
ip dhcp pool lan
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.231.203.132 192.231.203.3
lease infinite
ip cef
no ip bootp server
ip domain name internode.on.net
ip name-server 192.231.203.132
ip name-server 192.231.203.3
archive
log config
hidekeys
username admin secret
ip ssh time-out 90
ip ssh authentication-retries 2
interface ATM0
description --- Internode ADSL ---
no ip address
no shutdown
pvc 8/35
tx-ring-limit 3
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description --- Ethernet LAN ---
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1420
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname @internode.on.net
ppp chap password
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended MGMT-IN
permit ip 203.26.95.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended NAT
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class MGMT-IN in
login local
scheduler max-task-time 5000
sntp server 192.231.203.132
crypto key generate rsa mod 1024
end
Deepak Kumar
Please edit some ATM interface setting as below
interface ATM0/1/0
no ip address
no ip mroute-cache
dsl operating-mode auto
pvc 8/35
pppoe-client dial-pool-number 2
I hope your problem will resolve.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Amit Goyal
Try "ppp mtu adaptive" under dialer interface and check if it helps.
-Amit
