Problem with IP addresses?????
gregkurten
Our network works over our ISP's IP VPN cloud and we are running BGP. We have several sites connecting to our main area centre.
We have a device(eg laptop) at site X which connects to a device(laptop) at our HQ. If we make the device(site x) x.x.x.1 /30 and our router interface x.x.x.2 /30 and try to do a simple file share over the network the link is extremely slow,400 - 500bps, yet if we swap the IP's around,ie device x.x.x.2 and our router interface x.x.x.1, then the connection is fine. We are blaming our ISP and they are saying it's our configuration that is the problem. I have tried different routers and there is no difference. We had a CCIE at our office last week and he couldn't understand the problem!
All our links work over fibre and terminate on a Hauwei Echolife ONU.
Attached is a partial configuration of a router at one of our sites.
Is there anyone that has perhaps had a similar problem over IP VPN?
interface FastEthernet0/0 - TO ISP
ip address 10.1.1.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1 - TO LAN
ip address 192.168.21.2 255.255.255.252
duplex auto
speed auto
router bgp 65001
bgp router-id 10.1.1.2
bgp log-neighbor-changes
neighbor 10.1.1.1 remote-as 64517
address-family ipv4
redistribute static
neighbor 10.1.1.1 activate
no auto-summary
no synchronization
network 192.168.21.0 mask 255.255.255.252
exit-address-family
6 Replies 6
John Blakley
Can you post "sh int fa0/0" and "sh int fa0/1"?
HTH,
John
HTH, John *** Please rate all useful posts ***
I will do so when I get to the office in the morning(I work in Abu Dhabi)
Thanks!!
As requested.
Site A:
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0024.974e.10f0 (bia 0024.974e.10f0)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
Internet address is 10.1.1.122/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:03, output 00:00:03, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
17114 packets input, 19839708 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
26 input errors, 11 CRC, 15 frame, 0 overrun, 0 ignored
0 watchdog
22345 packets output, 9990891 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is down
Hardware is MV96340 Ethernet, address is 0024.974e.10f1 (bia 0024.974e.10f1)
Internet address is 30.30.30.2/30
Auto-duplex, Auto Speed, 100BaseTX/FX
Last input 22:24:38, output 00:00:06, output hang never
13919 packets input, 9258741 bytes
Received 127 broadcasts, 1 runts, 0 giants, 0 throttles
11 input errors, 0 CRC, 10 frame, 0 overrun, 0 ignored
0 watchdog
25388 packets output, 20079729 bytes, 0 underruns
Not a lot of data on the port as I was busy testing the link with Vanguard routers before I copied the config's.
Site B:
Hardware is MV96340 Ethernet, address is 0024.97c5.1828 (bia 0024.97c5.1828)
Internet address is 10.1.1.2/30
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 1000 bits/sec, 0 packets/sec
1243 packets input, 192966 bytes
Received 50 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
2826 packets output, 178042 bytes, 0 underruns
Hardware is MV96340 Ethernet, address is 0024.97c5.1829 (bia 0024.97c5.1829)
Internet address is 192.168.21.2/30
Last input 05:27:03, output 00:00:08, output hang never
285 packets input, 24636 bytes
Received 70 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
2256 packets output, 173672 bytes, 0 underruns
For starters, I would hardcode the duplex and speed settings. Try that and see if it helps. You don't have any CRC errors, which is usually and indication of mismatched duplex settings, but I would hard code to say the least.
I would also connect the routers the way that they're connected when you're having the problem, and then repost the "sh int" with the "slow" interface. I'm assuming that the slow interface is f0/1 when it's connected to the inside?
HTH,
John
Hi John
Thanks!
I'll post the configs tomorrow but it really doesn't matter how long the routers are connected. As soon as I connect them with this specific configuration the transfer between the 2 devices,both connected to the fa0/1interfaces, is slow. If I swap the the IP's around between the device and it's interface(fa0/1) then there's no problem!
Cheers
Greg
