problem with ipv6 route command
gentidisha
I'm trying to ping two PCs on packet tracer and between the two PC are two routers.
I'm trying to add an
ip route with ipv6 route
command but after I type the command the route does not show in the
show ipv6 route static
command.
Thank you
Harold Ritter
Hi @gentidisha ,
You inverted the IPv6 addresses between gi0/0 and gi0/1 on Router1:
You have
interface GigabitEthernet0/0
ipv6 address 2002::1/64
interface GigabitEthernet0/1
ipv6 address 2000::2/64
and it should be
You should be able to ping from PC0 to PC1 and vice versa after making that change.
8 Replies 8
balaji.bandi
basic steps :
enable ipv6 unicast routing
ipv6 unicast-routing
configure IPv6 address :
int Gi0/0
ipv6 address xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Static routing :
ipv6 route [ destination prefix ] [ outgoing interface ] [ next-hop ] [ AD ]
verify the route :
show ipv6 route
Note: you need to post the config that you configured for us to understand what is wrong and give suggestions.
BB
I uploaded the packet tracer file.
Thank you
Hello
Can you provide a bit more information on this please, the route will not show unless its specified next hop address is either on a directly connected interface or already exists in the route table.
Kind Regards
Paul
Thank you
ipv6 route destination prefix next-hop
<<- use this command
hi,
Thank you
there is no
ip route in IPv6
as I know.
as @paul driver  suggest share the config.
Harold Ritter
Hi @gentidisha ,
You have
and it should be
