Problem with ISDN backup
bradlesliect
Cisco 1721 Router
IOS: c1700-ipbasek9-mz.124-5a.bin
Config:
interface Dialer0
no description
ip address 192.168.225.238 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name cr1
dialer idle-timeout 180
dialer string <number removed>
dialer-group 1
fair-queue
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username <removed>
password 7 <removed>
ppp multilink bap
ppp multilink links maximum 2
ppp multilink links minimum 2
ppp multilink endpoint string client-backup
end
interface BRI0
description 6750
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
isdn calling-number 6750
fair-queue
ppp authentication chap pap
ppp multilink
end
sh debu
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn event is ON.
debug isdn silent errors is ON.
isd test call int br0 <number removed>
client-cr1#
001122: Dec 11 20:59:00.634 SAST: ISDN BR0 EVENT: UserIdle: callid 0x803C received ISDN_CALL (0x0)
001123: Dec 11 20:59:00.638 SAST: ISDN BR0 SERROR: isdn_get_guid: Cannot allocate a GUID (5)
001124: Dec 11 20:59:00.638 SAST: ISDN BR0 EVENT: process_bri_call: call id 0x803C, called_number <removed>, Guid 006243AC8262 speed 64, call type DATA, bchan -1 clng_num none
001125: Dec 11 20:59:00.638 SAST: ISDN BR0 SERROR: isdn_get_display_text_from_gtd: false ret
001126: Dec 11 20:59:00.638 SAST: ISDN BR0 SERROR: isdn_get_mlpp_from_gtd: MLPP from GTD failed
001127: Dec 11 20:59:00.666 SAST: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 89 changed to up
001128: Dec 11 20:59:00.826 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_INFORMATION
001129: Dec 11 20:59:02.542 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_PROCEEDING
001130: Dec 11 20:59:02.710 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_ALERTING
001131: Dec 11 20:59:02.734 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_CONNECT
001132: Dec 11 20:59:02.734 SAST: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
001133: Dec 11 20:59:02.734 SAST: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 00216572700 N/A
001134: Dec 11 20:59:03.550 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_DISCONNECT
001135: Dec 11 20:59:03.550 SAST: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
001136: Dec 11 20:59:03.602 SAST: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x803C calltype 1 HOST_DISCONNECT_ACK
001137: Dec 11 20:59:05.534 SAST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 89 changed to down
What's wrong with this picture? The config looks correct to me but the darn thing wont dial.
Ideas anyone?
thanks
5 Replies 5
dgahm
Level 8
Level 8
It looks like it is connecting, but dropping immediately.
Perhaps an authentication problem? debug ppp authentication
Please rate helpful posts.
Another thought is that the original post shows dialer-group 1 but does not show dialer-list 1. It would help to know if dialer-list is configured and if so what it has.
Rick
Rick
rick,
dialer list is configured.
dialer-list 1 protocol ip permit
ok ... get auth failure but username and passowrd is correct on both client router and the one they dial into.
What else can it be?
jarvar832004
check out the multilink string used on either sides.
It would help if debug q931 and q921 outputs are taken.
