problem with OSM-4OC3-POS-SI+ module on 7603S router
Alireza Karimi
we have a cisco 7603S router with "rsp720-3c 10ge" module.
we added an OSM-4OC3-POS-SI+ module in slot 2. This module has 4 gigabit ethernet port and 4 POS port.
But POS ports don't work. In fact the router doesn't recognize them.
Here is the router log at the boot time:
Nov 27 06:32:43.367: %C7600_PWR-SP-4-UNSUPPORTED: unsupported module in slot 2, power not allowed: The image for the card is not bundled in image.
*Nov 27 06:32:52.267: %OIR-6-REMCARD: Card removed from slot 2, interfaces disabled
But it shows 4 gigabitethernet ports:
Router#sh ip int br
     Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet1/1     unassigned      YES NVRAM  administratively down down
GigabitEthernet1/2     unassigned      YES NVRAM  administratively down down
GigabitEthernet1/3     unassigned      YES NVRAM  administratively down down
TenGigabitEthernet1/4  unassigned      YES NVRAM  administratively down down
TenGigabitEthernet1/5  unassigned      YES NVRAM  administratively down down
GigabitEthernet2/1     unassigned      YES NVRAM  administratively down down
GigabitEthernet2/2     unassigned      YES NVRAM  administratively down down
GigabitEthernet2/3     unassigned      YES NVRAM  administratively down down
GigabitEthernet2/4     unassigned      YES NVRAM  administratively down down
Vlan1                  unassigned      YES NVRAM  administratively down down
And here is the ouput of show version command:
Router#sh version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-IPSERVICES-M), Version 15.2(2)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 22-May-12 13:55 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-IPSERVICES-M), Version 15.2(2)S1, RELEASE SOFTWARE (fc1)
Router uptime is 47 minutes
Uptime for this control processor is 48 minutes
System returned to ROM by reload (SP by reload)
System image file is "sup-bootdisk:c7600rsp72043-ipservices-mz.152-2.S1.bin"
Last reload type: Normal Reload
Last reload reason: Reason unspecified
Cisco CISCO7603-S (M8500) processor (revision 1.0) with 917504K/65536K bytes of memory.
Processor board ID FOX1529GEJZ
BASEBOARD: RSP720-10GE
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
         I-cache 32 kB enabled
  Last reset from power-on
1 Virtual Ethernet interface
7 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
I changed my IOS to solve the problem but it didn't work. I tried this two IOSes:
     c7600rsp72043-adventerprisek9-mz.151-3.S2
     c7600rsp72043-adventerprisek9-mz.151-1.S2
I'm wondering is there anything wrong with OSM-4OC3-POS-SI+ module or not? Or maybe somthing else is the problem?
Any help is really appreciated.
Raju Sekharan
RSP720 doesn't support OSMs
Also as per below doc
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/7600_hwd.html#wp1080087
OSMs are not supported in the Cisco 7604 or in any S-series chassis.
Thank you
Raju
Thank you so much for your help.
Do you know what is the right module for 7603s with "rsp720-3c 10ge" module to have POS interfaces?
We need to have a POS (STM1) interface on our router.
