06-22-2011 11:22 AM - last edited on 03-25-2019 03:32 PM by ciscomoderator
I'm having an issue with policy routing on a 3560 switch running 12.2(50)SE1. We have the layer 3 switch routing for this remote location and it's default route is to the router that connects to our WAN across a Verizon MPLS circuit. I have two VLAN's created on the layer 3 switch. VLAN 1 is the default VLAN for all the clients. VLAN 2 is connected to an ASA firewall that is connected to a business class DSL line. We are trying to route the CEO's internet traffic at this location out the DSL connection. We also have a video conferncing system that is on VLAN 2 and has it's default gateway set to the ASA. We are able to make video calls through the ASA and over the DSL. Here's where the problem starts. I've created an access-list and a route-map to identify the traffic but I'm not seeing any matches for anything destined for the internet. I've applied the route-map to VLAN1. Any help would be greatly appreciated.
ip access-list extended BV_TEST_PBR
deny ip host 10.8.9.48 23.1.1.0 0.0.0.63 (The deny statements are for internal traffic that should go across the MPLS)
deny ip host 10.8.9.48 10.8.0.0 0.0.255.255
deny ip host 10.8.9.48 10.1.0.0 0.0.255.255
permit ip host 10.8.9.48 any (This should catch anything outside the networks i'm denying)
route-map BV_TEST_PBR permit 10
match ip address BV_TEST_PBR
set ip next-hop 10.8.10.254 ( This is the ASA inside interface)
ICSL3_SW#sh access-list BV_TEST_PBR (I have lots of matches for internal traffic but only 2 for other. I've done extensive internet broswing and no matches)
Extended IP access list BV_TEST_PBR
10 deny ip host 10.8.9.48 23.1.1.0 0.0.0.63 (2480 matches)
20 deny ip host 10.8.9.48 10.8.0.0 0.0.255.255 (102 matches)
30 deny ip host 10.8.9.48 10.1.0.0 0.0.255.255 (13285 matches)
40 permit ip host 10.8.9.48 any (2 matches)
ICSL3_SW#sh route-map BV_TEST_PBR
route-map BV_TEST_PBR, permit, sequence 10
Match clauses:
ip address (access-lists): BV_TEST_PBR
Set clauses:
Policy routing matches: 2 packets, 684 bytes (Hardly any matches even though I've been doing quite a bit of surfing and jumping around to different sites.)
ICSL3_SW#
06-22-2011 11:43 AM
Billy,
Would it be possible to post your entire configuration, or, at least, the configuration pertaining to the routing on your multilayer switch?
Best regards,
Peter
06-22-2011 11:51 AM
Billy
In addition to Peter's request. Looking at the "permits" in a PBR acl on a L3 switch is not a good indication of whether it is working or not because most of the packets will be hardware switched and therefore don't register as hits on the acl.
To test your PBR use traceroute from your source IP to see if it is being directed to the ASA.
Jon
06-22-2011 12:52 PM
Here's the config. I tried the traceroute and it was going back across our MPLS network. Interesting fact about the way the PBR works.
Building configuration...
Current configuration : 5492 bytes
! Last configuration change at 11:22:41 CST Wed Jun 22 2011 by bvaughn
! NVRAM config last updated at 20:02:13 CST Tue Jun 21 2011 by bvaughn
version 12.2
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no service dhcp
hostname ICSL3_SW
boot-start-marker
boot-end-marker
logging buffered informational
enable secret 5 $1$xZMy$u.SRFfZnUOlHoiX9nO3wS.
username sshadmin password 7 124B080211031A54232821
aaa new-model
aaa authentication login default group tacacs+ local
aaa session-id common
clock timezone CST -6
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name corp.rmic.com
password encryption aes
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
ip tcp synwait-time 10
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
speed 100
duplex full
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport mode access
speed 100
duplex full
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
switchport access vlan 2
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
description To ASA Firewall
interface FastEthernet0/37
description Omega ILO
speed 100
duplex full
interface FastEthernet0/38
description Omega
speed 100
duplex full
interface FastEthernet0/39
description To ICS 244
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/40
description To ICS 245
speed 100
duplex full
interface FastEthernet0/41
description To ICS 246
speed 100
duplex full
interface FastEthernet0/42
description To ICS 247
speed 100
duplex full
interface FastEthernet0/43
description To ICS 248
speed 100
duplex full
interface FastEthernet0/44
description To ICS 249
speed 100
duplex full
interface FastEthernet0/45
description To ICS 250
speed 100
duplex full
interface FastEthernet0/46
description To ICS 251
speed 100
duplex full
interface FastEthernet0/47
description To ICS 252
speed 100
duplex full
interface FastEthernet0/48
description To ICS RTR
speed 100
duplex full
interface GigabitEthernet0/1
shutdown
interface GigabitEthernet0/2
shutdown
interface GigabitEthernet0/3
shutdown
interface GigabitEthernet0/4
shutdown
interface Vlan1
description ICSDefGat
ip address 10.8.8.253 255.255.254.0
ip policy route-map BV_TEST_PBR
interface Vlan2
description VideoConf
ip address 10.8.10.253 255.255.255.0
router eigrp 110
passive-interface FastEthernet0/36
no auto-summary
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.8.8.254
no ip http server
no ip http secure-server
ip access-list extended CN_ACL
deny ip host 10.8.9.113 10.1.0.0 0.0.255.255
deny ip host 10.8.9.113 10.8.0.0 0.0.255.255
deny ip host 10.8.9.113 23.1.1.0 0.0.0.63
permit ip host 10.8.9.113 any
logging 10.10.1.200
route-map CN_PBR permit 10
match ip address CN_ACL
snmp-server community ******* RO
tacacs-server host 10.1.254.50 key 7 01010B0D58180E0E33494A
tacacs-server host 10.1.254.51 key 7 095E43001A161F13190900
tacacs-server directed-request
control-plane
banner motd ^Cogin#
This device is private property. Unauthorized access is not permitted. If you are unauthorized to access this device, you MUST disconnect immediate^C
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
ntp clock-period 36028518
ntp server 10.1.254.254
end
06-22-2011 01:27 PM
I wanted to update this post and let you know that it is working. Not sure why I had not thought about this earlier but I just Googled "what's my IP address" and it's showing the correct NAT IP address. I'm use to doing policy routing on a router and it normally shows correctly on the acl and route-map matches so I was a little thrown off by the numbers.
06-22-2011 01:49 PM
Jon,
Very true. Those pesky counters are increased only for software-switched traffic
Best regards,
Peter
