Problem with ppp Serial Link
njorosam
Hi all,
I have a 64K serial link using ppp encapsulation connecting a remote site from a central E1. The central E1 serial interface is showing up/down while the remote interface is up/up. I am able to ping the p2p interface in the remote site using my backup link to the site but cannot ping p2p interface in the central site hence the overall p2p connectivity on this link is down. Could someone offer some explanation for this?
paolo bevilacqua
Hi, send inte show interface taken on both routers.
Please see show int output from bothe routers. Central router has channelised E1.
3938 packets input, 244192 bytes, 0 no buffer
Received 0 broadcasts, 39 runts, 0 giants, 0 throttles
274 input errors, 39 CRC, 235 frame, 0 overrun, 0 ignored, 129 abort
The circuit has probably too many errors to work in PPP (fails negotiation), although it might marginally work in HDLC. In any case, you need the circuit repaired.
