Problem with sla tracking from Dialer Interface
mani98765
I would like to build a backup route, if my dsl line fails.
So I made a sla tracking on my dns server with source interface Dialer 1 and made a route with the tracking activated.
My problem is, that if I have this activated, I can't ping from Dialer 1 interface to my DNS Server, it seams, that it uses my backup route, instead of the source interface Dialer 1.
Have you got any idea, how to solve this problem?
Thank you
Manuel
EDIT:
If I make a static route to my DNS over Dialer 1, everything works fine. But so it seems, that even if I ping with source Dialer 1, it first looks into the routing table, and it don't choose the way over Dialer 1, it takes the way over my Backup route. How can I make this right, so it sends the ping out of Dialer 1, without have a  look into the routing table?
5 Replies 5
please post relevant configuration
Hello, this is the relevant configuration:
If the track is down, it pings via the backup route to the dns server, so if my backup is down and my main route is up, it will never switch back to the main route to my ISP.
track 1 ip sla 1 reachability
interface Dialer1
 ip address negotiated
 ip access-group WANin in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip virtual-reassembly
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp authentication chap callin
 ppp chap hostname *******
 ppp chap password *******
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.0.253 10
ip nat inside source list NATLIST interface Dialer1 overload
ip access-list standard NATLIST
 permit 192.168.0.0 0.0.0.255
 deny   any log
ip access-list standard TELNET
 deny   any log
ip access-list extended LANin
 permit ip 192.168.0.0 0.0.0.255 any
 permit udp any eq bootpc any eq bootps
ip sla 1
 icmp-echo 213.33.99.70 source-interface Dialer1
 timeout 1000
 threshold 2
 frequency 3
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
I don't know how you fixed this problem. but see link below for new command on the dialer interface to overcome this
http://www.cisco.com/c/en/us/support/docs/wan/point-to-point-protocol-ppp/200466-Track-PPP-session-over-Dialer-interface.html
A solution could be to use the command:
dialer down-with-vInterface
if available.
A different solution is to track the protocol status of the Dialer1 interface, given that the Dialer1 interface is always up:
track 10 interface Dialer1 ip routing
delay down 5 up 30
ip route 0.0.0.0 0.0.0.0 Dialer1 track 10
ip route 0.0.0.0 0.0.0.0 192.168.0.253 200
Gianrico Fichera
ITESYS SRL
Chosebin
So many days of reading and finally found this short thread with the right answer! Richard get's right but it MUST be used with the Gianrico's  track 10 interface Dialer1 ip routing to works correctly. Tested with Bell Canada's Fibe pppoe. Thank you guys.
