problem with WS-X6148-GE-TX in cat 6506
ilircisco
I have problem with the WS-X6148-GE-TX card in the switch 6500 with cat6000-sup2cv.6-4-20.bin .Tis card is not supported ,or "unknown card".Anybady help me please?
Thankyou
nethelper
Level 3
Level 3
you need either IOS 12.2.17-SX or CatOS 7.5(1) to support this card.
Nethelper
lgijssel
Level 9
Level 9
Checked the documentation for you. Please look at the Product and Software version matrix as contained in this URL:
http://www.cisco.com/en/US/customer/hw/switches/ps708/prod_release_note09186a008007f718.html#wp20834
You will need to upgrade your supervisor as recommended.
Leo
chuongnh
Hi you,
This module you use is supported with other IOS version. Cisco recommend you use version 7.6(9).
Goodluck!
Hello, I got the same problem with a 6509, the card WS-X6148-GE-TX is not being recognized. The devices has a Supervisor1A-2GE card running CatOS and IOS. What OS do I have to upgrade CatOS or IOS?
Please advice.
George
