Problems getting AV updates through an 1811W router
jyoung
We have a Cisco 1811W router for our gateway to the Internet. I just setup McAfee Groupshield on a new Exchange server. When I tried to run updates, they would fail. It uses HTTP over port 80 to download the updates. The updates would start to download and the progress bar would show the percentage of the file downloaded. After about 15 - 20 seconds, the percentage stopped. After about 45 minutes, it would finally fail (still at the same percentage downloaded).
I bypassed the router and directly connected to the Internet, and the update works fine. I recently had problems with some Exchange emails getting blocked at the firewall. I went into the Firewall | Application Security and turned off inspection on ESMTP and SMTP and that solved the problem. The router is setup to inspect TCP and UDP. I think that might be part of the problem, but I don't know what to change.
Has anyone had this problem or know how to fix it? I don't know a lot about routers, so if I am way off, let me know.
Jason
Here is some of the configuration of the router
version 12.3
ip subnet-zero
ip cef
ip domain name yourdomain.com
ip name-server 161.164.20.201
ip name-server 151.164.67.201
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW vdolive
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip ips po max-events 100
no ftp-server write-enable
5 Replies 5
John Blakley
I don't see an inspect for http traffic. You might try adding:
ip inspect name SDM_LOW http
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks for the response. I added the line and it still hangs.
Post entire config please.
Here's our config
SOLVED - I upgraded to IOS 12.4(15)T11 and it works. I think there was a bug in the code for Inspect commands.
