Problems with Cisco 887 3G functionality
fgoeijenbier
I have a question about the configuration of the 3G functionality on the cisco 887 router. The 3G connection should be the primary connection, because I don't have a direct internet connection. I make use of a data card of KPN NL. On the internet I found some information about the configuration of the 3G module, but won't get a 3G connection. If I look to the gsm profiles I see that the profile is still inactive. Can someone help me with the configuration of the 3G functionality and tell me how to activate the gsm profile?
Many thanks,
Frits
3 Accepted Solutions
pk21
Hi Frits,
Make sure the SIM card is not locked with a pin code, you can check from the router with
sh cell 0 security
If the output contains "SIM Status = Locked" then  type  cellular 0 gsm sim unlock [current pin code] to unlock the card.
When  you are sure there is no PIN, you can use the following template:
cellular 0/0/0 gsm profile create 1 office.vodafone.nl ipv4 pap vodafone vodafone
interface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username vodafone password 0 vodafone
end
dialer-list 1 protocol ip list 1
chat-script gsm "" "atdt*98*1#" TIMEOUT 30 "CONNECT"
line 0/0/0
exec-timeout 0 0
password vodafone
script dialer gsm
login
modem InOut
no exec
rxspeed 7200000
txspeed 2000000
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 permanent
Hi Frits,
OTASP activation is used only for CDMA cards (used in USA and India, mostly). In your case, being KPN NL, I assume is a GSM card.
The configuration you applied seems correct, except for the modem line.
You need to enable "modem inout" and associate the chat script under the line used by your modem. In your config, it should be line 3, but you can double check it with a "show line".
For example:
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
After that, you can enable these debugs:
- deb ppp nego
- deb chat
- deb dialer
In show cellular I see that the modem can already connect to KPN, with a good RSSI (-70), so once corrected the config you shouldn't have problems.
Let me know if it works
Cheers
Marco
OK, you can see that right now the profile is active, so IOS and modem are connected. You also got an IP address from the Telco:
Profile Information
Profile 1 = ACTIVE
Data Transmitted = 13179 bytes, Received = 0 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address = 188.206.51.54
For the debugs, change logging buffered to debugging instead of warnings, restart the cell link and check in show log.
If you try to ping from the cell interface (e.g. 8.8.8.8, google's DNS), it should work, can you try?
If you are trying to ping from the lan, the IP NAT config is incomplete, so it won't work.
Can you add the following:
interface vlan1
  ip nat inside
ip nat inside source list 23 interface cellular0 overload
(you have already access-list 23 configured, it will allow only lan's IP subnet)
Cheers
Marco
8 Replies 8
Giuseppe Larosa
Hello Fritz,
the exact procedure is carrier dependent and hardware dependent
have a look at configuration guide about activation of the modem see
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_evdo.html#wp1495984
there are also some older threads with answers from Cisco engineer Vespignani
Hope to help
Giuseppe
pk21
Hi Frits,
sh cell 0 security
ip nat outside
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
ppp chap refuse
end
line 0/0/0
exec-timeout 0 0
password vodafone
script dialer gsm
login
modem InOut
no exec
rxspeed 7200000
txspeed 2000000
Hi Giuseppe & pk21,
I think the activation of the modem still need to be done, but the command for activation is not working. I have tried the following command: cellular 0 cdma activate otasp *22899
I already unlocked the SIM card, and followed your template. The SIM card that I'm using is from KPN NL, and I received the following login information:
APN: internet
username: internet
password:
When I'm creating the gsm profile I need to enter a password as well, so I also entered internet as password.
Please find attached config file and cellular info.
Hi Frits,
For example:
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
- deb ppp nego
- deb chat
- deb dialer
Cheers
Marco
Hi Marco,
I have added the config for line 3, but still no internet connection available.
The debug commands are enabled, but didn't show any feedback (if I'm right). In the logging I see that the Cellular0 modem is inserted and that the modem is up.
New config file and cellular 0 interface added.
UPDATE: Now I see that my gsm profile is active, so there is a connection, only there is no internet. (both LED's are solid blue, not blinking anymore)
Profile Information
Profile 1 = ACTIVE
interface vlan1
  ip nat inside
Cheers
Marco
You were right first I was only able to ping from the cell interface to the DNS of Google. After adding the commands to my config, just as you said, the internet connection was also established on the connected devices. So everthing is working fine now.
Thanks a lot for all your help!
Cool! I'm glad it worked
Cheers
Marco
