problems with HSRP, iBGP
srue
Level 7
Level 7
I have 2 3660's [12.2(7a)] running HSRP between the two, and configured as iBGP peers. They exchange all routes learned from their respective eBGP peers, AT&T, and Sprint. Router1 (AT&T), is the primary HSRP router. After attempting to download the latest IPS updates from Cisco (ftp-sj.cisco.com/198.133.219.27), it kept timing out. A traceroute from an internal server indicated it was going out the Sprint connection (HSRP 2ndary router), due to the iBGP route exchanges. The download would get to about 300Kb and timeout. We have a PIX515E (6.3(5)) behind the HSRP routers. If I put a static route in the PIX to go to the 2ndary HSRP router for the cisco FTP site, it downloads just fine. Any suggestions on how to fix this, as I'm guessing Cisco is not the only affected site. (ip-redirects are turned off on the HSRP routers)
PLEASE HELP :)
TIA
mchin345
Level 6
Level 6
Did you check the physical interfaces for CRC errors. If the download starts and then suddenly stops this may be a physical layer problem. Check on this.
nothing significant with CRC errors. Last thursday I ended up moving both circuits to one physical router, taking iBGP and HSRP out of the picture. Everythign works fine now. I think we are getting two new routers in a couple months, so i think the setup will probably stay like this for now. Thanks for the reply.
