Problems with VLANs between cisco 7200 routers
jlamanna1
I have a point to point link between 2 Cisco 7200s that I'm being
required to add VLAN tagging to.
Here are the interface configs:
Router A:
interface FastEthernet5/0
no ip address
duplex full
interface FastEthernet5/0.253
encapsulation dot1Q 253
ip address xxx.xxx.xxx.249 255.255.255.252
Router B:
interface FastEthernet4/0
no ip address
duplex full
interface FastEthernet4/0.253
ip address xxx.xxx.xxx.250 255.255.255.252
However, when AT&T forces tagging on the ports, I cannot ping from .
249 to .250, and AT&T cannot see my MAC address on their switches
inbetween and zero traffic on the VLAN.
Does anyone have any ideas?
Router A is a 7206VXR running 12.2(4r)
Router B is a 7204VXR running 12.2(12a)
Thank you.
Jon Marshall
Can you check with your provider
1) That they have configured the link as 802.1q trunk
2) That vlan 253 exists on their switch infrastructure
Jon
Yes.
I know they have configured the link as 802.1q on vlan 253.
I had a similar issue on a couple of our routers they are 2811s, but probably a similar situation. I had to to VLAN tagging for a different reason, but had similar results. What I wound up doing was to remove the IP address from the subinterface and put on apply to the parent interface. Here is a snippet from the config.
interface FastEthernet0/1
ip address xx.xx.245.65 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1.1
description $ETH-LAN$
encapsulation dot1Q 20
no snmp trap link-status
Once I did that it worked fine.
The HQ end was different because of the hardware we used.
