PROVIDING IP ADDRESSES TO VLAN BY L3 SWITCH
vkarthik.cs
I know how to give the dynamic ip by router to its networks.
But i like to give the dynamic ip to vlan by L3 switch.
Is it possible?:?? I want a help?
enable
config t
service dhcp
ip dhcp excluded-address x.x.x.x  x.x.x.x  ---> range of static IPs you want to exclude from dhcp pool
no ip dhcp conflict-logging
ip dhcp pool mypool
network x.x.x.x / x  ---> subnet + prefix length
default router x.x.x.x  ---> the default gateway: address of the vlan interface in same subnet as the pool
dns-server x.x.x.x x.x.x.x   ----> the dns servers
Regards.
Alain
8 Replies 8
cadet alain
you can use a  switch as DHCP server without any problem.
the configuration is the same but  to be sure just activate the service first: service dhcp in global config
Regards.
Alain
Thank you sir,,,,can u say the switching commands for that..............i am waiting for that
enable
config t
service dhcp
ip dhcp pool mypool
Regards.
Alain
vkarthik.cs
very very thank you sir.............but i have one doubt.......i.e
we have one dhcp server for providing ip to vlan(different)
suppose if i am configuring l3 switch as dhcp to provide ip to vlan(differnt).
Is there any wrong that 2 dhcp server in network?
if you've got multiple servers then the fastest one to respod to DHCP discover will be the one providing the IP.
if the router is in another subnet and you  can't communicate with it then it won't be no problem.
tell us exactly what you wanrt to achieve.
Regards.
Alain
am already having one dhcp server on network.....it will give ip to one vlan
now am going to configuring router as dhcp....to provide ip to another vlan......
so is there any by this?./...........this is my question..........
are these 2 servers on same subnet? if not then the vlan that is attached to the switch dhcp server will be broadcasting the dhcp discovers and so if you've got no dhcp relay agent configured the other server will never see a discover message so it won't be a problem.
Regards.
Alain
