PSU errors
HCL Support
We getting below given logs on 3945 router. Is it bug or hardware failure?
Mar 28 12:46:24.771: %ENVMON-5-POWER_NOTICE: : Chassis power supply is UP in PSU 1
Mar 28 12:46:25.211: %ENVMON-3-POWER_ERROR: : Unable to read the PSU EEPROM information.
Mar 28 12:46:26.215: %ENVMON-5-POWER_NOTICE: : Chassis power supply is UP in PSU 1
Mar 28 12:46:26.655: %ENVMON-3-POWER_ERROR: : Unable to read the PSU EEPROM information.
Mar 28 12:46:27.659: %ENVMON-5-POWER_NOTICE: : Chassis power supply is UP in PSU 1
Mar 28 12:46:28.099: %ENVMON-3-POWER_ERROR: : Unable to read the PSU EEPROM information.
Mar 28 12:46:33.103: %ENVMON-5-POWER_NOTICE: : Chassis power supply is UP in PSU 1
Show ver:
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 01-Jun-11 19:43 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Mumbai-AP-RTR-2 uptime is 2 minutes
System restarted at 19:32:51 IST Tue Mar 28 2017
System image file is "flash0:c3900-universalk9-mz.SPA.150-1.M6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.1) with C3900-SPE150/K9 with 980992K/67584K bytes of memory.
Processor board ID
3 Gigabit Ethernet interfaces
26 Serial interfaces
4 Serial(sync/async) interfaces
4 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash 0 (Read/Write
Leo Laohoo
Version 15.0(1)M6
Uhhhh ... WTF.  This a very, very old IOS.
Kindly upgrade the IOS and see if it improve things.
we will upgrade and update..
