10-18-2020 05:01 PM
I've successfully created a sub-interface for VLAN10 but when I try to create one for VLAN20 I keep getting a "BAD MASK" message or "IP ADDRESS OVERLAPPING". I may be getting the words twisted up from my professor but I am having issues with assigning an IP to the sub-interface. Any help or tips with this?
10-18-2020 05:51 PM - edited 10-18-2020 05:56 PM
Hi @SchwabVang
Zip your exercise (winzip) and attach it to check.
Meanwhile, you can verify that you are not assigning a network IP address on the interface, remembering that you must assign a host IP on the interfaces, within the corresponding network.
10-18-2020 11:17 PM - edited 10-18-2020 11:17 PM
Hello
FYI-
router 1
int x/x
description facing rtr2
192.168.1.241 mask 255.255.255.252
int x/x
description facing sw0
no shut
int x/x.10
encapsulation dot1q 10
ip address 192.168.1.1 255.255.255.224
int x/x.20
encapsulation dot1q 20
ip address 192.168.1.33 255.255.255.224
router 2
int x/x
description facing rtr1
192.168.1.242 mask 255.255.255.252
int x/x
description facing sw1
no shut
int x/x.30
encapsulation dot1q 30
ip address 200.10.10.1 255.255.255.192
int x/x.40
encapsulation dot1q 40
ip address 200.10.10.65 255.255.255.192
