putty "Network error: Connection refused" - router 2911 public ip
Balaji Ezhumalai
Hello all,
I have cisco 2911 router with public IP enabled.
I am able to connect my router through putty SSH using my private IP, and it works fine.
But when I try to connect the router using public IP from outside the network, it says "Network error: Connection refused".
Here is some information about router configuration for your reference:
#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
DeaJon1 uptime is 5 days, 23 hours, 14 minutes
System returned to ROM by reload at 09:34:10 UTC Wed Oct 20 2021
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1427AHQ4
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FTX1427AHQ4
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase    ipbasek9    Permanent    ipbasek9
security     None         None            None
uc              uck9       Permanent      uck9
data          None         None            None
NtwkEss    None        None             None
CollabPro  None        None             None
Configuration register is 0x2101
#show ip ssh
SSH Enabled - version 2.0
Authentication methods: publickey, keyboard-interactive, password
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded):
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQCMueDzv0jZEIG/sbuDnTka5Td3cbnMo8XyPFkfR0ND
sD+RB+czPka7Xayj/9UvjficXJ6nabvBmpXvysZDrKiC4VEncBh6iG10QzZqnANhHLyMv3hjONhJW94W
5qEeYvRhLJG1689mTmrwX3aBSqF4vSH1auzRKW5+maKAaZmhcw==
#show run | s line
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
# show run (ip nat details)
ip nat pool NAT_POOL X.X.X.X   X.X.X.X netmask X.X.X.X
ip nat inside source list 10 pool NAT_POOL overload
ip route X.X.X.X    X.X.X.x    X.X.X.X
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
Please help and thanks in advance.
Balaji Ezhumalai
Hello All,
An IOS update has fixed this issue.
The previous version was "15.4(3)M1" and I have updated it to "15.7(3)M8".
Now I am able to ssh the router using its public IP address.
Thanks.
8 Replies 8
Seb Rupik
Hi there,
Are there any ACLs configured on Gi0/0 ?
cheers,
Seb.
Hi, thanks for attending my question,
Yes,
access-list 10 permit X.X.X.X X.X.X.X
Here is the G0/0 information
please check the attachment.
Hi Seb,
More information here:
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address X.X.X.X    255.255.255.0
ip nat inside
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
ip nat pool NAT_POOL X.X.X.X    X.X.X.X netmask 255.255.255.0
ip route X.X.X.X   255.255.255.0   X.X.X.X
access-list 10 permit  X.X.X.X    0.0.0.255
Hi Seb,
I have not solved this problem yet, any advice?
your router supports SSH version 2 only:
--> SSH Enabled - version 2.0 (version 1.99 would mean it is backwards compatible with version 1).
Make sure you use the very latest version of Putty (link below):
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
You could also try to zeroize and regenerate the crypto key, that often helps:
crypto key zeroize
crypto key generate
Hi Mr. Georg,
Thanks for attending my question.
1. I am using the latest version of putty, I even uninstalled my putty and reinstalled from the given link.
2. Like you suggested, I have regenerated the crypto key
But still the problem exist, I am not able to access my router using public IP.
any other options please!!
thanks again
Balaji Ezhumalai
Hello All,
Thanks.
