07-13-2011 05:24 AM - edited 03-04-2019 12:58 PM
I'm trying to establish a second connection to a different ISP using a single ATM/HWIC-ADSL Line as per this document: http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/mpppoec.html
The router is running Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
When i try to add the second dial-pool-number to ATM I get the following error:
Enter configuration commands, one per line. End with CNTL/Z.
rtr(config)#interface ATM0/0/0
rtr(config-if)# pvc 8/35
rtr(config-if-atm-vc)# oam-pvc 0
rtr(config-if-atm-vc)# pppoe-client dial-pool-number 3
% pvc already member of PPPoA dialer pool
rtr(config-if-atm-vc)# !
rtr(config-if-atm-vc)#!
Current Config is:
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
no atm ilmi-keepalive
pvc 8/35
oam-pvc 0
pppoe-client dial-pool-number 1
interface Dialer0
description Primary ISP
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
interface Dialer2
Secondary ISP
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
encapsulation ppp
dialer pool 3
dialer-group 3
no cdp enable
Johan Hanekom
Solved! Go to Solution.
07-13-2011 10:31 AM
Hi Johan,
Well, at least I know now exactly what you are trying to accomplish but the funny thing is that I do not know why your router prevents you from doing that. It definitely should, and your original way of configuration was correct.
You are absolutely correctly trying to run a new PPPoE client over the same PVC which should be supported on IOSes 12.4(15)T and newer. However, despite running IOS 12.4(24)T3, your router does not accept running a second PPPoE client on the same PVC. Even more strange, the router complains that the PVC is already in a PPPoA dialer pool which is illogical as you are not running PPPoA.
This may be an IOS bug. Do you have an option of upgrading to either the newest 12.4T or 15.0M IOS? Using a G.SHDSL interface in my lab, I could configure my router to establish two PPPoE sessions over a single ATM PVC exactly as the original document suggested:
interface ATM0/1/0
no ip address
pvc 1/32
oam-pvc 0
pppoe-client dial-pool-number 2
interface Dialer1
encapsulation ppp
dialer pool 1
interface Dialer2
encapsulation ppp
dialer pool 2
Router#show ip int brief
FastEthernet0/0 unassigned YES unset administratively down down
FastEthernet0/1 unassigned YES unset administratively down down
Serial0/0/0 unassigned YES unset administratively down down
Serial0/0/1 unassigned YES unset administratively down down
ATM0/1/0 unassigned YES unset up up
Dialer1 192.0.2.2 YES IPCP up up
Dialer2 192.0.2.1 YES IPCP up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up up
The router is running Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2).
Besides that, does the show atm pvc ppp produce any interesting output? That should show you PPPoA sessions - if there are any which they should not, according to your configuration.
Best regards,
Peter
07-13-2011 05:51 AM
Johan,
I doubt that what you are trying to accomplish is realistic. A single ATM PVC that provides the data delivery within the basic DSL service is a point-to-point data conduit. It has only a single end terminated at one particular ISP (simplified a bit but basically valid). You cannot have a single PVC go to two different ISPs. If you want to use a single DSL interface to connect to two different ISPs then
interface Dialer0
encapsulation ppp
ppp chap hostname user@isp1.com
ppp chap password XXX
dialer pool 1
interface Dialer2
encapsulation ppp
ppp chap hostname user@isp2.com
dialer pool 1
The unique login will then help your DSL service provider to properly tunnel your session towards your two ISPs.
Best regards,
Peter
07-13-2011 06:34 AM
Hi Peter
I changed the config but now dialer2 is not connecting even with a static route:
ip route 172.29.1.0 255.255.255.0 Dialer2 permanent
rtr#sh ip int brief
FastEthernet0/0 xxx.xxx.97.1 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM up up
ATM0/0/0 unassigned YES NVRAM up up
NVI0 xxx.xxx.97.1 YES unset up up
Virtual-Access3 unassigned YES unset up up
Dialer0 xxx.xxx.102.167 YES IPCP up up
Dialer1 xxx.xx.199.236 YES IPCP up up
Dialer2 unassigned YES NVRAM up up
Loopback0 xxx.xxx.6.50 YES NVRAM up up
rtr#
Johan Hanekom
07-13-2011 07:00 AM
Hello Johan,
Can you please post your current configuration? It is difficult to debug a configuration that is not known ...
Best regards,
Peter
07-13-2011 07:50 AM
Hi Peter
See below:
Johan Hanekom
Current configuration : 12356 bytes
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
pvc 8/35
oam-pvc 0
interface Dialer0
description ISP1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username user@isp1.com password 7 xxxxxxxxxxxxxxxxxxxxxxxxx
service-policy output EDGE-VOICE
interface Dialer2
description ISP2
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname user@dsl-isp2.com
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username user@dsl-isp2.com password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxx
07-13-2011 08:35 AM
Johan,
The problem that the route through Dialer2 does not appear in your routing table is based on the fact that the Dialer2 has not received any IP address from your ISP - basically, it has not become an IP-operational interface. Why is that I cannot say right now. Perhaps the Dialer2 was not able at all to negotiate a connection to your ISP.
Remove the ppp authentication chap pap callin command and do not replace it with any other similar command. Then please shutdown the Di2 interface and start these debugs:
debug pppoe events
debug ppp negotiation
debug ppp authentication
After all these debugs are in place, enter the no shutdown command on the Di2 interface, capture the debug output and post it here please for further analysis. Thanks!
Best regards,
Peter
07-13-2011 09:22 AM
Hi Peter
I've remove the ppp auth and no change. see below:
rtr(config)#interface dialer 2
rtr(config-if)#shutdown
rtr(config-if)#
rtr#
000090: *Jul 13 18:07:39.190 PCTime: Di2 DDR: dialer shutdown complete
000091: *Jul 13 18:07:40.322 PCTime: %SYS-5-CONFIG_I: Configured from console by spme on vty0 (xxx.xxx.5.92)
000092: *Jul 13 18:07:41.190 PCTime: %LINK-5-CHANGED: Interface Dialer2, changed state to administratively down
rtr#
rtr#
rtr#debug pppoe events
PPPoE protocol events debugging is on
rtr#debug ppp negotiation
PPP protocol negotiation debugging is on
rtr#debug ppp authentication
PPP authentication debugging is on
rtr#conf
rtr#configure t
rtr#configure terminal
rtr(config)#int
rtr(config-if)#no su
rtr(config-if)#no sh
rtr(config-if)#no shutdown
rtr(config-if)#
000093: *Jul 13 18:08:08.278 PCTime: %LINK-3-UPDOWN: Interface Dialer2, changed state to up
rtr(config-if)#
rtr(config-if)#
rtr(config-if)#
rtr#sh ip int br
Dialer1 xxx.xxx.199.236 YES IPCP up up
Johan Hanekom
07-13-2011 09:29 AM
Hi Peter
When I shutdown Dialer0, Dialer2 connected, see below:
Johan Hanekom
rtr(config)#interface dialer0
rtr(config-if)#shu
000096: *Jul 13 18:14:39.450 PCTime: PPPoE : Shutting down client session
000097: *Jul 13 18:14:39.450 PCTime: [0]PPPoE 52008: O PADT R:0017.5a88.4524 L:0024.97c2.2488 8/35 ATM0/0/0
000098: *Jul 13 18:14:39.450 PCTime: Vi3 IPCP: Remove link info for cef entry xxx.xxx.86.1
000099: *Jul 13 18:14:39.450 PCTime: Vi3 PPP: Sending Acct Event[Down] id[4]
000100: *Jul 13 18:14:39.450 PCTime: Vi3 IPCP: State is Closed
000101: *Jul 13 18:14:39.450 PCTime: Vi3 PPP SSS: Send DISCONNECT to mgr_hdl[2F000003]
000102: *Jul 13 18:14:39.454 PCTime: Vi3 PPP: Phase is ESTABLISHING, renegotiate LCP
000103: *Jul 13 18:14:39.454 PCTime: Vi3 PPP: Authorization NOT required
000104: *Jul 13 18:14:39.454 PCTime: Vi3 PPP: No remote authentication for call-out
000105: *Jul 13 18:14:39.454 PCTime: Vi3 LCP: O CONFREQ [Closed] id 3 len 10
000106: *Jul 13 18:14:39.454 PCTime: Vi3 LCP: MagicNumber 0x25993B6A (0x050625993B6A)
000107: *Jul 13 18:14:39.454 PCTime: PPPoE: Vi3: No Session, Packet Discarded
000108: *Jul 13 18:14:39.478 PCTime: %DIALER-6-UNBIND: Interface Vi3 unbound from profile Di0
000109: *Jul 13 18:14:39.490 PCTime: Vi3 PPP: Block vaccess from being freed [0x10]
000110: *Jul 13 18:14:39.490 PCTime: Di0 DDR: dialer shutdown complete
000111: *Jul 13 18:14:39.506 PCTime: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to down
000112: *Jul 13 18:14:39.522 PCTime: Vi3 PPP: Sending Acct Event[Down] id[4]
000113: *Jul 13 18:14:39.522 PCTime: Vi3 LCP: State is Closed
000114: *Jul 13 18:14:39.522 PCTime: Vi3 PPP: Phase is DOWN
000115: *Jul 13 18:14:39.522 PCTime: Vi3 PPP: Unlocked by [0x10] Still Locked by [0x2]
000116: *Jul 13 18:14:39.522 PCTime: Vi3 PPP: Unlocked by [0x2] Still Locked by [0x0]
000117: *Jul 13 18:14:39.522 PCTime: Vi3 PPP: Free previously blocked vaccess
000118: *Jul 13 18:14:39.550 PCTime: Di0 IPCP: Remove route to xxx.xxx.86.1
000119: *Jul 13 18:14:39.562 PCTime: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 661488C0 - looped chain attempting to stack
000120: *Jul 13 18:14:40.450 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
000121: *Jul 13 18:14:40.494 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
000122: *Jul 13 18:14:40.494 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
000125: *Jul 13 18:14:59.502 PCTime: Sending PADI: vc=8/35
000126: *Jul 13 18:14:59.510 PCTime: PPPoE 0: I PADO R:0017.5a88.4524 L:0024.97c2.2488 8/35 ATM0/0/0
000127: *Jul 13 18:15:01.550 PCTime: PPPOE: we've got our pado and the pado timer went off
000128: *Jul 13 18:15:01.550 PCTime: OUT PADR from PPPoE Session
000129: *Jul 13 18:15:01.558 PCTime: PPPoE 58563: I PADS R:0017.5a88.4524 L:0024.97c2.2488 8/35 ATM0/0/0
000130: *Jul 13 18:15:01.562 PCTime: IN PADS from PPPoE Session
000131: *Jul 13 18:15:01.562 PCTime: %DIALER-6-BIND: Interface Vi3 bound to profile Di2
000132: *Jul 13 18:15:01.562 PCTime: PPPoE: Virtual Access interface obtained.
000133: *Jul 13 18:15:01.562 PCTime: PPPoE : encap string prepared
000134: *Jul 13 18:15:01.562 PCTime: [0]PPPoE 58563: data path set to Virtual Acess
000135: *Jul 13 18:15:01.562 PCTime: Vi3 PPP: Phase is DOWN, Setup
000136: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: Using dialer call direction
000137: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: Treating connection as a callout
000138: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: Session handle[8A00000C] Session id[0]
000139: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: Phase is ESTABLISHING, Active Open
000140: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: Authorization NOT required
000141: *Jul 13 18:15:01.566 PCTime: Vi3 PPP: No remote authentication for call-out
000142: *Jul 13 18:15:01.566 PCTime: Vi3 LCP: O CONFREQ [Closed] id 1 len 10
000143: *Jul 13 18:15:01.566 PCTime: Vi3 LCP: MagicNumber 0x259991D2 (0x0506259991D2)
000144: *Jul 13 18:15:01.566 PCTime: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to up
000145: *Jul 13 18:15:01.578 PCTime: Vi3 LCP: I CONFACK [REQsent] id 1 len 10
000146: *Jul 13 18:15:01.578 PCTime: Vi3 LCP: MagicNumber 0x259991D2 (0x0506259991D2)
000147: *Jul 13 18:15:03.550 PCTime: Vi3 LCP: Timeout: State ACKrcvd
000148: *Jul 13 18:15:03.550 PCTime: Vi3 LCP: O CONFREQ [ACKrcvd] id 2 len 10
000149: *Jul 13 18:15:03.550 PCTime: Vi3 LCP: MagicNumber 0x259991D2 (0x0506259991D2)
000150: *Jul 13 18:15:03.558 PCTime: Vi3 LCP: I CONFACK [REQsent] id 2 len 10
000151: *Jul 13 18:15:03.558 PCTime: Vi3 LCP: MagicNumber 0x259991D2 (0x0506259991D2)
000152: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: I CONFREQ [ACKrcvd] id 2 len 18
000153: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: MRU 1492 (0x010405D4)
000154: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: AuthProto PAP (0x0304C023)
000155: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: MagicNumber 0x5D7E9938 (0x05065D7E9938)
000156: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: O CONFNAK [ACKrcvd] id 2 len 8
000157: *Jul 13 18:15:03.582 PCTime: Vi3 LCP: MRU 1500 (0x010405DC)
000158: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: I CONFREQ [ACKrcvd] id 3 len 18
000159: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: MRU 1500 (0x010405DC)
000160: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: AuthProto PAP (0x0304C023)
000161: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: MagicNumber 0x5D7E9938 (0x05065D7E9938)
000162: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: O CONFACK [ACKrcvd] id 3 len 18
000163: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: MRU 1500 (0x010405DC)
000164: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: AuthProto PAP (0x0304C023)
000165: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: MagicNumber 0x5D7E9938 (0x05065D7E9938)
000166: *Jul 13 18:15:03.594 PCTime: Vi3 LCP: State is Open
000167: *Jul 13 18:15:03.594 PCTime: Vi3 PPP: Phase is AUTHENTICATING, by the peer
000168: *Jul 13 18:15:03.594 PCTime: Vi3 PAP: Using hostname from interface PAP
000169: *Jul 13 18:15:03.594 PCTime: Vi3 PAP: Using password from interface PAP
000170: *Jul 13 18:15:03.594 PCTime: Vi3 PAP: O AUTH-REQ id 1 len 36 from "user@dsl-isp2.com"
000171: *Jul 13 18:15:03.646 PCTime: Vi3 LCP: I CONFREQ [Open] id 1 len 14
000172: *Jul 13 18:15:03.646 PCTime: Vi3 LCP: AuthProto PAP (0x0304C023)
000173: *Jul 13 18:15:03.646 PCTime: Vi3 LCP: MagicNumber 0xE23FB9E9 (0x0506E23FB9E9)
000174: *Jul 13 18:15:03.650 PCTime: Vi3 PPP: Sending Acct Event[Reneg] id[B]
000175: *Jul 13 18:15:03.650 PCTime: Vi3 PPP: Phase is TERMINATING
000176: *Jul 13 18:15:03.650 PCTime: Vi3 PPP: Authorization NOT required
000177: *Jul 13 18:15:03.650 PCTime: Vi3 PPP: No remote authentication for call-out
000178: *Jul 13 18:15:03.650 PCTime: Vi3 PPP: Phase is ESTABLISHING
000179: *Jul 13 18:15:03.650 PCTime: Vi3 LCP: O CONFREQ [Open] id 3 len 10
000180: *Jul 13 18:15:03.650 PCTime: Vi3 LCP: MagicNumber 0x259999FA (0x0506259999FA)
000181: *Jul 13 18:15:03.650 PCTime: Vi3 LCP: O CONFACK [Open] id 1 len 14
000182: *Jul 13 18:15:03.650 PCTime: Vi3 LCP: AuthProto PAP (0x0304C023)
000183: *Jul 13 18:15:03.650 PCTime: Vi3 LCP: MagicNumber 0xE23FB9E9 (0x0506E23FB9E9)
000184: *Jul 13 18:15:03.662 PCTime: Vi3 LCP: I CONFACK [ACKsent] id 3 len 10
000185: *Jul 13 18:15:03.662 PCTime: Vi3 LCP: MagicNumber 0x259999FA (0x0506259999FA)
000186: *Jul 13 18:15:03.662 PCTime: Vi3 LCP: State is Open
000187: *Jul 13 18:15:03.662 PCTime: Vi3 PPP: Phase is AUTHENTICATING, by the peer
000188: *Jul 13 18:15:03.662 PCTime: Vi3 PAP: Using hostname from interface PAP
000189: *Jul 13 18:15:03.662 PCTime: Vi3 PAP: Using password from interface PAP
000190: *Jul 13 18:15:03.662 PCTime: Vi3 PAP: O AUTH-REQ id 2 len 36 from "user@dsl-isp2.com"
000191: *Jul 13 18:15:04.030 PCTime: Vi3 PAP: I AUTH-ACK id 2 len 5
000192: *Jul 13 18:15:04.030 PCTime: Vi3 PPP: Phase is FORWARDING, Attempting Forward
000193: *Jul 13 18:15:04.030 PCTime: Vi3 PPP: Queue IPCP code[1] id[1]
000194: *Jul 13 18:15:04.046 PCTime: Vi3 PPP SSS: Receive SSS-Mgr Connect-Local
000195: *Jul 13 18:15:04.046 PCTime: Vi3 PPP: Phase is ESTABLISHING, Finish LCP
000196: *Jul 13 18:15:04.046 PCTime: Vi3 PPP: Phase is UP
000197: *Jul 13 18:15:04.046 PCTime: Vi3 IPCP: O CONFREQ [Closed] id 1 len 10
000198: *Jul 13 18:15:04.046 PCTime: Vi3 IPCP: Address 0.0.0.0 (0x030600000000)
000199: *Jul 13 18:15:04.046 PCTime: Vi3 PPP: Process pending ncp packets
000200: *Jul 13 18:15:04.046 PCTime: Vi3 IPCP: Redirect packet to Vi3
000201: *Jul 13 18:15:04.046 PCTime: Vi3 IPCP: I CONFREQ [REQsent] id 1 len 10
000202: *Jul 13 18:15:04.046 PCTime: Vi3 IPCP: Address xxx.xxx.255.250 (0x03069BEFFFFA)
000203: *Jul 13 18:15:04.050 PCTime: Vi3 IPCP: O CONFACK [REQsent] id 1 len 10
000204: *Jul 13 18:15:04.050 PCTime: Vi3 IPCP: Address xxx.xxx.255.250 (0x03069BEFFFFA)
000205: *Jul 13 18:15:04.058 PCTime: Vi3 IPCP: I CONFNAK [ACKsent] id 1 len 10
000206: *Jul 13 18:15:04.058 PCTime: Vi3 IPCP: Address xxx.xxx.1.2 (0x0306AC1D0102)
000207: *Jul 13 18:15:04.058 PCTime: Vi3 IPCP: O CONFREQ [ACKsent] id 2 len 10
000208: *Jul 13 18:15:04.058 PCTime: Vi3 IPCP: Address xxx.xxx.1.2 (0x0306AC1D0102)
000209: *Jul 13 18:15:04.070 PCTime: Vi3 IPCP: I CONFACK [ACKsent] id 2 len 10
000210: *Jul 13 18:15:04.070 PCTime: Vi3 IPCP: Address xxx.xxx.1.2 (0x0306AC1D0102)
000211: *Jul 13 18:15:04.070 PCTime: Vi3 IPCP: State is Open
000212: *Jul 13 18:15:04.070 PCTime: Di2 IPCP: Install negotiated IP interface address xxx.xxx.1.2
000213: *Jul 13 18:15:04.074 PCTime: Di2 IPCP: Install route to xxx.xxx.255.250
000214: *Jul 13 18:15:04.078 PCTime: Vi3 IPCP: Add link info for cef entry xxx.xxx.255.250
000215: *Jul 13 18:15:05.046 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
07-13-2011 09:33 AM
Johan,
I have to apologize. During the time, I overlooked that what you are using is PPPoA. Unfortunately, that makes my idea with different usernames useless.
Originally, I thought you are using PPPoE. The PPPoE would allow you to create two distinct sessions over a single PVC and each of these sessions could be forwarded to a different ISP. Unfortunately, with PPPoA, it is not possible. PPPoA simply takes PPP frames, chops them into ATM cells and carries them over the ATM PVC circuit to the aggregation router at the ISP. Because there can be only a single PPP session established over the PVC here, it is not possible to have simultaneous sessions running over the same PVC to two different ISPs. Because the PVC is currently used by the Di0 interface, shutting and activating the Di2 interface did not have any effect because there was no free PVC for Di2. I suspect that if you deactivated Di0 and activated Di2, the Di2 would come up and the Di0 would be unable to come up.
The only options I see now is either to convert to PPPoE - which depends on your DSL service provider - or to really get another PVC.
I apologize for not catching this sooner in the process.
Best regards,
Peter
07-13-2011 09:46 AM
Hi Peter
No problem, how can I convert my config to PPPoE?
Johan Hanekom
07-13-2011 10:01 AM
Johan,
Please forgive me once again. I am a total idiot. Seeing no output from the "debug pppoe events" and referring to your thread name, I assumed you are running PPPoA.
However, the fact is that you are indeed running a PPPoE (the "pppoe-client dial-pool-member" command under your PVC), and I have blindly missed that as well. I am really getting senile or something...
Let me go over the original article you have referenced once more, and perhaps test something in my lab, but it may take some time. So far, just please accept my apologies for constantly confusing you.
Best regards,
Peter
07-13-2011 10:31 AM
Hi Johan,
interface ATM0/1/0
no ip address
pvc 1/32
oam-pvc 0
interface Dialer1
encapsulation ppp
dialer pool 1
interface Dialer2
encapsulation ppp
dialer pool 2
Best regards,
Peter
07-13-2011 02:47 PM
Johan,
One more addition. If the Cisco Feature Navigator (http://cisco.com/go/fn) is to be trusted then the multiple PPPoE clients on ATM PVCs on 1841 routers are supported only in the 15.0M and newer IOSes with the Advanced IP Services feature set. That would be congruent with my experiments performed on the 15.0(1)M3.
Best regards,
Peter
07-14-2011 04:20 AM
Hi Peter
Thanks for the update and the brilliant support, unfortunately the router doesn’t have enough memory to run 15.0M.
I’ll try 12.4 (24) T5 and see if it works, according to the release notes there was a problem in the version I’m running, see below:
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TCAVS.html
CSCtd74943
Symptoms: Multiple PPPoE clients cannot be configured on a single ATM VC.
Conditions: This symptom is observed under all conditions.
Johan Hanekom
07-15-2011 05:44 AM
Hi Peter
Just a quick update, I've upgraded to IOS 12.4(24)T5 and this resolve my problem.
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
pvc 8/35
oam-pvc 0
sh ip int brief
Virtual-Access4 unassigned YES unset up up
Dialer0 xxx.xxx.86.125 YES IPCP up up
Dialer1 xxx.xxx.33.208 YES IPCP up up
Dialer2 xxx.xxx.1.2 YES IPCP up up
Thanks again.
Johan Hanekom
