Community Helping Community
144
Beginner
PVC's not showing in routing table in Frame Relay
I have a frame relay setup where there are three routers connected to a Frame Relay Cloud and each router is connected to one another by a PVC that I have created using sub interfaces on each router.  My question is, when I do a show IP Route, I do not see the PVC's listed in the routing table.  The routing table is blank.  I have attached my Packet Tracer File.  Can anyone please shed some light on this for me?  I have investigated this for much time and cannot find any resolution.
Thanks.
1 REPLY 1
Beginner
Hey Marc,
I looked over your packet tracer and you have everything on the routers configured correctly. The problems were with the "ISP" cloud device:
  • Created Frame-Relay Mappings on the Cloud Device. (Allowed Data to traverse the network through the "ISP" Cloud Device)
  • Adjusted the LMI types on the cloud device to ANSI (Brought Serial connections up)
Hope this helps
Content for Community-Ad
FusionCharts will render here
