QinQ NCS-5501
Rob Sciarrino
I'm trying to configure two NCS-5501's running IOS-XR with a QinQ interface for a customer on each end.  Apologies if I'm getting my Encaps types wrong, but essentially we are tagging any traffic from the customer with VLAN200 internally.
I've been looking at Cisco docs and feel I'm overcomplicating things.  Can someone point me to the correct publication or give a quick config example?
Thanks in advance
M02@rt37
Hello @Rob Sciarrino
On NCS-5501#1 (Customer Facing)
interface GigabitEthernet0/0/0/1
description customer-facing-int
encapsulation dot1q 200 second-dot1q any
rewrite ingress tag pop 1 symmetric
l2transport
On NCS-5501#2 (Customer Facing)
description cust-facing-int
l2transport
On Internal Link Between NCS-5501 #1 and NCS-5501#2:
interface GigabitEthernet0/0/0/2
description internal-QinQ
l2transport
sources:https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/vpn/75x/b-l2vpn-cg-ncs5500-75x/configure-virtual-LANs-in-layer-2-VPNs.html
Best regards
M02@rt37
l2transport
l2transport
l2transport
Best regards
Thanks!  What I was looking for!
This configuration works for tagged and untagged packets on the attachment circuit for the XRv9000. No guarantees that it is a platform independent config that will also work on the NCS 5500.
interface GigabitEthernet0/0/0/2.200 l2transport
description QinQ trunk
interface GigabitEthernet0/0/0/4
description Attachment circuit
l2transport
l2vpn
xconnect group s-tag-200
p2p ac2trunk
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
