08-07-2022 09:39 AM
I am in need of some fine tunning on my QoS and CoPP configurations. I have a remote ISR router and I need to prioritize traffic to/from my subnet 10.10.0.0/24 over a 10Mbps Ethernet WAN connection. Here is what I have so far:
ip access-list extended critical-data
permit ip 10.10.0.0 0.0.0.255 any
permit ip any 10.10.0.0 0.0.0.255
class-map match-any critical-data
match dscp ef
policy-map qos-to-wan
class critical-data
!!priority 1!!
int g0/0
service-policy output qos-to-wan
I need to understand how to I allow the 10Mbps ethernet wan connection for allowance.
Thank you for any help.
John
08-07-2022 10:14 AM
Do you have any other subnet in the remote location other than mentioned in the example :
you can use ACL to setup a reserved bandwidth for that subnet :
acces-list 100 permit ip 10.10.0.0 0.0.0.255 any
class-map match-any MYREMOTEIP
match access-group 100
policy-map MYPRIORITY
class MYREMOTEIP
bandwidth xxxxxx ( you can setup bandwidth here in KB)
interface gig0/0
Service-policy output MYPRIORITY
08-08-2022 08:15 AM
You don't use your subnet in any of your policy matching, and unclear where that subnet is relative to your g0/0 interface (physically running at 10 Mbps, or running at a higher bandwidth but with a contracted 10 Mbps? - very critical difference!).
What are your CoPP requirements?
What's the nature hi-priority traffic? DSCP EF is generally only used for VoIP.
