QoS could not apply on BVI
plada
I have one problem about QoS with router which configured as Service Provider recommended(int BVI).
After I made QoS configuration and I applied it to s0/0/0 interface.
Then I confirmed it's working or not by using command
"show policy-map int s0/0/0"
But result show that no packet goes to each classes.
Then I tried to research to create new policy to apply on sub-interface.
After that still same result(no packet goes to each classes).
So I made one access-list permit ip any any to check matched packets on s0/0/0
and s0/0/0.1, result is no matched packet though these 2 interfaces.
And if I put same access-list on BVI interface, they could show many matched packets.
But big problem is I could not apply CBWFQ or GTS (Shaping) to BVI interface for making QoS.
I already tried hard to research but still not get some answer.
So I decided to ask for help from expert here, could you please help me.
Note: Another sites, without BVI interface but same configuration
are working fine until now.
drolemc
Level 6
Level 6
Understanding Packet Counters in show policy-map interface Output.
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml#confirmpol
morphic99
I've got the same issue here - does anyone have any ideas?
Thanks guys!
