QOS in 3560
sajism220
I am facing an issue with QOS in 3560 switch, we are doing the QOS in ingress mode. We are setting the total bandwidth 5MB.Please find below script which we are following.
pa5-rn-mf-idf1-c1#sh version
"flash:/c3560-ipbase-mz.122-44.SE2.bin"
pa5-rn-mf-idf1-c1#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
pa5-rn-mf-idf1-c1#
class-map match-all video
match access-group name video
policy-map ingress-cctv
class video
set precedence 4
police 5000000 375000 exceed-action drop
interface FastEthernet0/1
description ***Connected to CCTV***
switchport access vlan 200
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input ingress-cctv
interface GigabitEthernet0/1 //Uplink ports to distribution switch
description Link to porto5-dist1 Gig1/1
switchport trunk native vlan 999
switchport trunk allowed vlan 17,200
switchport mode trunk
udld port aggressive
spanning-tree guard loop
ip access-list extended video //Access list for matching the IP traffic
permit ip 10.160.0.0 0.0.255.255 239.160.0.0 0.0.255.255
Switch Output shown after the QOS settings.
pa5-th-gf-idf1-c1#sh mls qos interface fastEthernet 0/1 statistics
FastEthernet0/1 (All statistics are in packets)
dscp: incoming
0 - 4 : 262168080 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 2755773 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 13727 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 262168184 0 0 0 0
5 - 7 : 0 0 0
cos: outgoing
0 - 4 : 6234152 0 0 0 0
5 - 7 : 0 772565 0
Policer: Inprofile: 171538294 OutofProfile: 1
Can you confirm me how we can confirm the QOS is working fine ?? policy map doesn't show anything.
Marwan ALshawi
hi there
exactly as Giuseppe suggested, you have to check it on the other end of the switch
lets say you connected a router to other end
creat a class map as bellow
class-map map1
match precedence 4
policy-map p1
class map1
on the router interface connected to the 3560
int fa
service-policy p1 intput
now do show policy-map int fa
you have to see traffic mcoming under map1
and you have to see the max linit as your policed traffic limit
if any of the above not shown you need to check your switch config
good luck
Giuseppe Larosa
Hello Saij,
you should look at the other end of the uplink switch to see if there are incoming frames with a DSCP compatible with IP precedence 4.
setting a specific DSCP value could make easier to check.
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swqos.html#wp1322872
or
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swqos.html#wp1322872
Hope to help
Giuseppe
Marwan ALshawi
hi there
class-map map1
match precedence 4
policy-map p1
class map1
int fa
good luck
Thanks for the quick response,I will check the same and update..
Joseph W. Doherty
If the traffic you're marking flows out g0/1, its stats should show the marked packets.
As to policing, I think, "Policer: Inprofile: 171538294 OutofProfile: 1 ", (shown for f0/1), indicates the policer results.
[edit]
PS:
re: Giuseppe's
"setting a specific DSCP value could make easier to check"
It's likely you'll see your IP Prec 4 as DSCP CS4 marked packets, but Giuseppe is correct that setting IP Prec 4, you could have any or 8 DSCP values. If you want to avoid this possiblity mark as CS4.
