I notice that QoS can't be applied at subinterface level but there are two ways to do it in a frame-relay environment which I mention at the subject of this discussion.
Now my question is, does this do gives the same result?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Don't recall my ever using native frame-relay shaping. I've used GTS with frame-relay and CBWFQ (MQC?) shaping. GTS, if I remember correctly, supports WFQ implicitly, as does pre-HQF CBWFQ shaping in class-default. GTS and, I believe, frame-relay shaping can also slow their rates when they receive BECNs although I also recall frame-relay shaping has more control over that than GTS. All 3, I also believe, are very similar in how they meter out shaped packets.
